Steve, no Avalon rooms?
No, saw Luciene though at the show and they had decided not to go since they had just spent a good sum of money expanding the factory last year
While I have seen it twice in other shows, this time I could not even go in his room today. The door was closed and locked!!! How the heck do these people do business this way???
You can pick up a router a the corner 7-11 these days. Was the really the reason he closed shop?No what happened was that Dan's router went down today and he couldn't demoProbably should have put a note though on the door gone fishing
I think so. Rich and I were in his room and he was desperately trying to get the router working. Suspect though problem wasn't the router but the Venetian's Wifi/internet because heard it was overloaded by the number of people at CES (same happened at RMAF a year ago).
I am totally fried.
No, saw Luciene though at the show and they had decided not to go since they had just spent a good sum of money expanding the factory last year![]()
Another speaker we heard was Perfect 8 which is a small $150K speaker with the drivers in plexiglass and no enclosure. Good but not great. Apparently RH and JV gave it contender for Best In Show. Not sure what they were smoking before listening and $150 K. ????
Just left the convention floor. Saw the LG 3D OLED. if you're going to see it wear diapers because you'll need it. I have said many times I am not a fan of 3D. Until now. All of 4mm thick and color that is jaw dropping. The 3D was like nothing I have ever seen. No motion artifacts and off axis 3D that can be seen way off to the side. Sony and Samsung had their OLED. Both very good but the LG clearly was the best video product there
I am totally fried.
Try a cold compress in your forehead Steve. :b
* Thanks for all the reporting and dedication to WBF family.
I spent Vout 1/2 hour in the scaena room. They had the smaller series (12 drivers per side) and the huge subs in static display in the front if the room. It sounded very good one thing which bothered me about their set up was with the ribbon tweeters to the inside rather than the outside as I feel it should be however the reps said definitely not. Any thoughts Elliott when you set them up.
BTW the subs are huge and look like the front of a jet plane. If I would buy the speaker I would use different subs. I passed Nola several times but no music coming from the room so didn't go in
