Site Founder, Site Co-Owner, Administrator
IIRC way back when first released Emile stated 1000 hours are required to charge the capacitors. The good news is that it only continues to get better. There is no downside@Malcng:I'm at day 10 or 11, with approx.100 hours on the Extreme. Also sounding great. Did you observe a settling in period? I did, it seemed to have awoken at about 50-60 hours. With my limitations I couldn't have set it up without Taiko's assistance. (Christiaan) Are you connected ethernet directly to the Extreme? If so I would recommend a inexpensive switch I'm using a Netgear GS 105. Simple little tweak that can work well in certain networks.
as for file transfer I also use USB direct into a usb Input to Extreme. I recently transferred almost 10 TB’s in well under 10 hours. Leave front button always on. My issue now is that I’m almost out of internal memory and have discussed options with EmIle
