It can be... with expectation bias!Now that's funny! Too bad it wasn't a glass of Knob's Creek or WT 101.
(...) Then I must be deaf as a post or dumb. When we acquired Pacific Microsonics, the makers of HDCD, one of their engineers gave me a quick test of HDCD vs CD version of the same. I swore to him that the HDCD version sounded so much more open, had more detail, etc only to have him tell me that he was playing the CD version both times! After he told me this, I took the test again and this time they both sounded the same. You can say that expectation bias of them being the same wiped out the imagined differences
Sorry could not resist.![]()
Amir,
When you say "quick test" you are saying it all. No "quick test" will show any small differences in a reliable way, and in these conditions you will be much more open to suggestion.
Now, with that said, I don't doubt that biases change or are replaced by others over time and if you continue to do a lot of comparative listening you may very well find something that compares better and change your original opinion. But can you hear subtle differences better over hours or days than you can by switching rapidly between the two things you're comparing. No one doing the research seems to think so. No one testing hearing seems to think so. Only audiophiles seem to believe this.
Tim
Agreed here Tim, over the many known and unknown variables from which we "rank" a good from a bad system/component, one tends to sort them differently over time, this just happened to me while evaluating a loaned preamp which was mine some years back, now I am finding attributes that are compelling with my tastes which were either unperciptible or niot relevant when I first had it. - this applies for an inexact market definition.
I've said this many times before, but it bears repeating at least as often as this audiophile myth is repeated. The science says that the opposite is true, that our auditory memory is very short. our ability to adapt our perceptions to meet our expectations is long, and that exactly the opposite is true -- the only reliable way to identify very subtle differences is through quick switching between what's being tested. Long-term listening is completely unreliable for identification of subtle differences. (...)
If they are audible now, they were audible then, it is your perceptions, attitude, needs, taste...you...that has changed. The inanimate object, unless it is no longer functioning properly, is unchanged.
Tim
Do you know of any loudspeaker manufacturer that develops speakers listening exclusively to three minutes periods in blind conditions?
On the issue of time: it does take considerable amount of time to learn to hear non-linear artifacts and material that best exposes that. So long term evaluation is good that way. But when it comes time to A/B comparison, speed is everything. You can easily test that yourself. Compress some material and do quick AB tests vs longer listening. You will find the quick AB to far more effective.
How so? I ask because my experience has bee the exact opposite.BTW, IMHO, training people to look for some kind of artifacts makes them less sensitive to others.
This perfectly encapsulates what's wrong with all this DBT business, it very mistakenly believes that you can take the unpredictable, untrustworthy "human" element of decision making out of the process, but all it really does is compound the issue in many, if not most, situations. The nature of the the human organism is that it gets very irritated, very irked at setups which cripple its ability to understand precisely what's going on, so frequently in these environments I'm sure a lot of the answers are made from the perspective of "I couldn't care less any more whether I'm right or wrong; I just want to get out of this situation!" ...I think there is a big difference between listening at home with no pressure to come to the *right* answer and form your opinion with as much time as it takes vice feeling consciously or subconsciously pressured to make a quick decision on which sample under test sounds better and making a mistake as a result.
And herein lies a real dilemma in this audio business. Tim is exactly right, that quick switching will identify real differences between 2 versions with genuine, but slight differences. What undoes the value of this is that the differences are not static, they depend upon the relatively long term stabilisation of the system to manifest properly, and the better the system the more this is relevant. You're caught between the devil, and the deep ...I've said this many times before, but it bears repeating at least as often as this audiophile myth is repeated. The science says that the opposite is true, that our auditory memory is very short. our ability to adapt our perceptions to meet our expectations is long, and that exactly the opposite is true -- the only reliable way to identify very subtle differences is through quick switching between what's being tested. Long-term listening is completely unreliable for identification of subtle differences.
I'm sure DBT will work beautifully when the situation being assessed is static, that is, absolutely nothing varies in the state of the 2 situations, A and B: before the switching takes place, during the period of the changeover, and following the switching, for an indefinite period of time. Most research matters do deal in such situations, so there are no real problems.Expectation bias never, ever takes a vacation and one exhibits not a shred of humility by even suggesting one is immune from it. This forum has been active for 1 year and 9 months and I continue to read the same misunderstandings and straw man arguments regarding blind testing and bias, both of which are universally accepted as gold standards in measuring the perceptual world. Only capital A Audiophiles proclaim themselves with superhuman abilities. What a serious disservice to the audio hobby it is. What's Best Forum? Nah, at least in this thread this is Audio Asylum.
