I knew I wasnt imagining what I heard Lukasz sayI just got definitive word from @Lukasz "Lampizator" Fikus via Fred @LampiNA that it is ok to leave the right 2 rear tube sockets empty when using the DAC in single-ended mode.
What about the middle tubes "L Neg And Pos" and "R Neg and Pos"?I just got definitive word from @Lukasz "Lampizator" Fikus via Fred @LampiNA that it is ok to leave the right 2 rear tube sockets empty when using the DAC in single-ended mode.
Are both needed also in SE mode?
Or can one also be left out in SE mode?
So really only the right two pentodes can be left out in SE mode?They are both needed.
You saved me some time for typing - thanksI wish I could get over my OCD disease because if I could I would take out the right pair of TS KT170 and leave the slots empty but I need to have balance in my life and if I looked at 2 empty slots or two slots on the right filled with different tubes than the slots on the left I would probably have a nervous breakdown trying to resist my temptation to make the right side the same
Between you and dminches making recommendations, you have made me fall victim to collecting backup sets so that I can watch those 2 tubes on the right look just as pretty as the ones on the leftYou saved me some time for typing - thanks
While on that I think You should get a quad of EL51s and EL156s for the starterBetween you
Curse the two of you because I also remember Lukasz saying that even though those two right tubes are not necessary for SE, they burn out at the same rate as those on the left It's like watching money evaporate into electrons
Then there all sold outGiven that Horizon is limited to 400 units, what happens when they’re all sold out?
It will take another 2 years so let's not worry. There will be something - but probably not better just almost as good. We bought the last remaining processors on Earth.Given that Horizon is limited to 400 units, what happens when they’re all sold out?
Best of the best - made in SerbiaThey were made in Serbia and sold under Telefunken name. The local brand name was Ei. They are phenomenal.
