Or VNC if you are using Roon.Click the front button twice. 1 click just turns on the video (I think).
Or, you can restart from the app.
I have no clue what is happening (perhaps my cache was too large and impacting performance? omg no idea). But, I am headed back to listen and re-reconfirm what I am hearing.
That’s correct. One short tap and then a second the first turns off videoClick the front button twice. 1 click just turns off the video (I think).
To me, this is the most overlooked variable -- that is, one's metal state, and ability to give attention to the music with a fresh and un-cluttered mind.The most variable aspect of the system is the human being sitting in the listening chair.
The buffers need to be set for the DACDAC question: When one puts in a different DAC after the Extreme and using TAS, is it usually plug and play or does some fiddling have to take place?
Are there different Buffer settings dependent on DAC?The buffers need to be set for the DAC
from what I recall there are 4 buffer settings and you need to know which setting to use for your DACAre there different Buffer settings dependent on DAC?
This method is pretty straightforward. I use a cheap Pioneer player I bought on EBay. I’ve ripped over 100 SACD’s to DSD 64 with it.Nice, I’ve been thinking about how to best rip my CDs at a high bitrate…
I started out ripping SACDs with an early Playstation 3 that hadn't had its firmware updated past the point where Sony had disabled the ripping crack. Those Playstations are very hard to find now and most are unreliable due to heat issues in the early versions.This method is pretty straightforward. I use a cheap Pioneer player I bought on EBay. I’ve ripped over 100 SACD’s to DSD 64 with it.
SACD Ripping using an Oppo or Pioneer? Yes, it's true!
Note: I told the PS3 thread I would announce what I've found, so I am writing this first post, long before I am ready to (i.e I don't have the links ready yet, nor the instructions). I expect my second post to be ready in a few more days. Thanks to some very ingenious folks on other forums around...audiophilestyle.com
TAS (LMS) scanning struggles with special characters in the Folder name. Removing or changing these special characters fixes the problem sometimesthis is a problem that i know will go away with xdms, but is annoying.
even after a re-scan, i'm not able to see (in TAS) all of my music.
for example, only 5 of the 9 Beethoven symphonies by Savall show up in the music folder
selection, yet i can see that all 9 are on the drive.
any suggestions?
i guess i could delete the current one and do a complete re-scan (versus an incremental one)............
Thanks Christoph, In fact, I created that post in Roon Forum but there isnt much help so I tried my luck here. Now that Roon acknowledged there is a software problem and they are investigating it. Hope it will get fixed soon.Hi Rocco,
this is currently a general Roon problem, not related to Taiko / SGM.
Roon on my Extreme is working just fine, while Roon on a friend's Non-Taiko Server is exhibiting the same problem you are describing.
There is a thread on the roon forum called "search in roon stopped working", you might want to check progress there.
Christoph
Hi Rocco,Thanks Christoph, In fact, I created that post in Roon Forum but there isnt much help so I tried my luck here. Now that Roon acknowledged there is a software problem and they are investigating it. Hope it will get fixed soon.
any suggestions?
Which model T+A is that ?While playing DSF512 Jazz at the Pawnshop with TAS, very often the music would disappear while the track time counter is still counting. The music would return at the start of the next track and randomly might disappear again. The cycle goes on for the whole album. When switch to Roon, the album play normally. Any suggestions? Thanks
I have had the same problem and have mentioned it here before. I have found a fix in my system. When the blue bar is moving but there is no sound, I can easily correct the problem by pushing the stop button. Then I push the reverse button and then I push play again and it always corrects the problem at my end. I have found that this issue can occur regardless of which format is being playedWhile playing DSF512 Jazz at the Pawnshop with TAS, very often the music would disappear while the track time counter is still counting. The music would return at the start of the next track and randomly might disappear again. The cycle goes on for the whole album. When switch to Roon, the album play normally. Any suggestions? Thanks
