P plasmod3 Well-Known Member Aug 28, 2020 677 548 183 45 May 7, 2022 #1 Have a tube question for the learned Is there a preference between a c3g vs a we 437a to use in an amp? I hear the we is sweeter but the c3g is more linear? Very very keen on thoughts
S Sablon Audio Industry Expert, VIP Donor May 22, 2015 1,673 1,592 648 May 8, 2022 #2 Buy both Ian - I think that’s the answer you really wanted
P plasmod3 Well-Known Member Aug 28, 2020 677 548 183 45 May 8, 2022 #3 Sablon Audio said: Buy both Ian - I think that’s the answer you really wanted Click to expand... N9t that simple my friend one has a choice as to which one goes into the amp and its an expensive mistake if I get it wrong haha Reactions: Sablon Audio
AMR / iFi audio Industry Expert Aug 21, 2019 2,635 1,047 260 44 UK ifi-audio.com May 25, 2022 #4 plasmod3 said: N9t that simple my friend one has a choice as to which one goes into the amp and its an expensive mistake if I get it wrong haha Click to expand... It's very hard to guess what will you like more. Can you tell us what kind of hardware are you using? What kind of improvement are you looking for?
P plasmod3 Well-Known Member Aug 28, 2020 677 548 183 45 May 25, 2022 #5 AMR / iFi audio said: It's very hard to guess what will you like more. Can you tell us what kind of hardware are you using? What kind of improvement are you looking for? Click to expand... Well it's for the wavac 833, which is better in combination I guess. No chance to change after the build
