The more I think about it the more I think many are embarrassed by their failure to notice the emperor has no clothes.
This is all that matters. If it sounds good to you it is good for you.I have no horse in this race, except that I like MQA sound in my system
I agree and this goes for all formats IMO. I know when I was looking for a DAC based on the ones I had in my home/system the sound varied.I keep saying mqa is great but the dac we use matters way beyond what we may think. I have some 4 mqa dacs of them 2 are ok one is wow. How we feel on all other formats of a particular dac should not be used to judge mqa sound. I’m just saying what I have heard is all.
but to me in MQA its worse . i dont know why understand it . my gustard does great mqa , pcm too dsd is ok not best . my toppings is fine in dsd and pcm , MQA is horrible to . its nutsI agree and this goes for all formats IMO. I know when I was looking for a DAC based on the ones I had in my home/system the sound varied.
I have had a mix in my comparisons of different formats on different DACs. I can't say one format like MQA was always worse for me. For me it depended on the quality of the recording. Even now when I build a playlist I tend to put in the best sounding recording regardless of the format.but to me in MQA its worse . i dont know why understand it . my gustard does great mqa , pcm too dsd is ok not best . my toppings is fine in dsd and pcm , MQA is horrible to . its nuts
Keeping in mind that MQA stands for 'Master Quality Assured'. To do that you would really have to start with the actual master. Just sayinI can't say one format like MQA was always worse for me.
AIFF is PCM, any bit depth and sampling rate. WAV and AIFF contain the same musical data, with differences in metadata coding.What do you think of AIFF
as a format ?
also 16 but depth compared to 24 but depth
just curious as you seem to hear changes some feel don’t exist ?
Which is why I can't say if MQA is better or worse than the original. For me it really is as simple as me listening to the song. If it sounds good I really don't care what format it is in. If I have a choice of different formats of a song I like, I will listen to both and whichever one sounds better to me is the one I prefer.Keeping in mind that MQA stands for 'Master Quality Assured'. To do that you would really have to start with the actual master. Just sayin
"Authenticated" rather than "Assured", although the intention is the same. And it's hard to see how the resulting sound will be the same no matter what DAC (not even considering the rest of the system) is used, just because the blue light is lit.Keeping in mind that MQA stands for 'Master Quality Assured'. To do that you would really have to start with the actual master. Just sayin
Ok you answered my question and I thank you for it.AIFF is PCM, any bit depth and sampling rate. WAV and AIFF contain the same musical data, with differences in metadata coding.
I hear or see it this way"Authenticated" rather than "Assured", although the intention is the same. And it's hard to see how the resulting sound will be the same no matter what DAC (not even considering the rest of the system) is used, just because the blue light is lit.
This means little, since the MQA file is already altered from the original. You would need to find a hi-res PCM file encoded from the same master as the MQA file (ideally at the same time) to make this a meaningful comparison.I hear or see it this way
mqa in part is to stream a sound that is better align the data stream to get there improved effects
for me I always hear a better sound on a given track if we turn off the mqa and then back on
I'm not sure what you are trying to say here. AIFF, WAV and uncompressed FLAC all contain the same PCM data; the differences are in the amount and type of metadata. There is a group of audiophiles who feel that WAV sounds the best of the 3, possibly because of less metadata and therefore less use of the CPU (although considering that in a modern PC not even optimized for audio playback the CPU typically uses less than 5% when playing any of the formats that hypothesis may not be valid)Ok you answered my question and I thank you for it.
Now not to derail or argue the in increase in bit depth allows for a lower noise by many db. this to me and this is me sounds less hash compared to 16 but depth
If we try an AB for me it’s obvious
in sound while numbers show us what it may sound like. some will say it’s an improvement
some dacs may show a sound change.
also if we consider AIFF is a lossless zero compression when compared to flac even if no Compression is picked
Ok I’ll reply in a few but for now it’s are not just bits. i also willI'm not sure what you are trying to say here. AIFF, WAV and uncompressed FLAC all contain the same PCM data; the differences are in the amount and type of metadata. There is a group of audiophiles who feel that WAV sounds the best of the 3, possibly because of less metadata and therefore less use of the CPU (although considering that in a modern PC not even optimized for audio playback the CPU typically uses less than 5% when playing any of the formats that hypothesis may not be valid)
