Good to know.So I finally received the Russ Andrews unit. It was held up in customs for a week.
Today, I have connected it to my chassis ground's and also tried connecting it to my Entreq units. I can honestly say at least at this short time with it (a few hours) it does nothing.
ozzy
How did you connect it to your Entreq units?So I finally received the Russ Andrews unit. It was held up in customs for a week.
ozzy
Entreq has offered two models, Atlantis Minimus and Atlantis Tellus, since day one to supercharge any ground box model, nothing new. I am still using one Atlantis Minimus myself. They may have been discontinued after the born of those T ground boxes.Yeah I just read the article.
Question:
Has anyone tried daisy chaining a couple of Entreq boxes together? My experience with my Silver Tellus and my DIY box tells me it works good. Increases the benefit.
ozzy
This is the exact same article from Enjoy The Music you posted earlier this month with the exception that the North America distributor has instructed the reviewer to fixed up the ground box model name and retail price.![]()
Entreq Olympus Infinity T - Positive Feedback
Entreq Olympus Infinity T Ground Box And Entreq Eartha Ground Cablespositive-feedback.com
When you say the Russ Andrews unit is connected to your Entreq via banana does that mean from the connector that was designed to link the Russ Andrews "Router" to the copper rod (i.e., you are using the Entreq as the end point instead)?This is what I posted on Audiogon.
I have my Entreq Silver Tellus connected to the (source) RCA’s to my Lumin X1 and JL CR-1 Crossover. No preamp is used.
The Entreq then is also connected to my very large DIY ground box (pictures on my systems page) which also connects my subs and amps via banana’s
The Russ Andrews unit is connected to my:
My speakers are connected to a couple of my DIY ground box(s) for speakers.
- Niagara 7000 to a DIY AC plug (with just the ground connected).
- Connected to my Entreq via Banana
- Connected to my Lumin X1 chassis ground terminal on the separate power supply.
ozzy
Then it is the equivalent of the Puritan Groundmaster City devices which I have shared my experiences with, and cannot be used with your Entreq units. As I've described, I have two units - one for chassis grounding of power conditioner and power supply, and a 2nd for signal grounding of integrated amp and sacd player. As I reported, signal grounding via unused rca inlets resulted in a significant improvement - much more than the chassis grounding.The Russ Andrews unit I am using plugs into the wall outlet not to an outside ground rod. I thought connecting it to my Entreq was a good thing, at least initially. Today, I have disconnected that connection and only have the Russ Andrews unit connected to my Lumin X1 ground terminal and into my AudioQuest Niagara 7000 AC (ground only).
ozzy
thanks ozzy.I have now decided that the Russ Andrews ground into the Niagara 7000 was not necessary. It actually sounds better without it.
So at this point, I am using the Russ Andrews unit to the chassis of my Lumin X1 power supply and my JL Audio CR-1. Still undecided on its usefulness.
Signal grounds (RCA) are plugged into my Entreq/DIY grounding boxes/
ozzy
