Site Founder, Site Co-Owner, Administrator
I Don't leave my Horizon on contrary to Lukasz suggestionsMaybe then that's not good . The Bendix 6900 is more durable and is 5000 hrs
so you need 3 pr of 5687 per yr ouch
The back one is always on in my system. I'll ask Fred what is bestDo you turn off the back power switch or just the front. What does each control?
You are actually on double deck for my NA orders, but it is indeed time to start getting excited!Fred texted that I am next in line on the production schedule. Confirmed that it will be Duracell. I'm just copying Steve. Larry
that's why I have 3 sets of NIB 6900The hours mean nothing in the specs. In the same fashion a passenger sedan will last 20 minutes in a race. Having said that 6900 is the champion bar none.
Great point there Steve, am curious too. Hope yoga can advise@Lukasz....a question that many of us have ben asking......re the quad pentodes and using the Horizon single ended rather than balanced.....
In single ended the two pentodes on the left are in operation. Are the 2 pentodes on the right side working at full throttle like the pair on the left or are they in standby or ???
we ask because we wonder when the left two tubes fail, can we switch the two tubes on the right to the left and put those on the right to the left
IOW do. the 4 tubes fail together or just the 2 on the left fail first. I remember you said to just insert 2 inexpensive pentodes in the right bank but most of us are obsessive compulsive and like the look of 4 tubes the same. However we have no idea what the tube life will be on the right bank. Is it the same as the two on the left or is it longer because they are no being used for single ended
I run single ended David. Running balanced doesn't help as my preamp and amp are SE. Lamm does not believe in balanced. At any rate, I did get an answer from Lukasz that all should read......Steve, are you using the single-ended outputs? I am using that for now but plan on going to balanced at some point because my run is about 3 meters from the DAC to my preamp.
