Site Founder, Site Co-Owner, Administrator
Sorry. My mistake. I was looking at Wil’s photosI didn’t post a picture of them.
I haven’t yet heard the Horizon, a friend is hopefully going to get his in May, very much looking forward. Having said that, I’ve heard the Takatsuki in several constellations, and while it’s all system dependent and generalizations aren’t more than just that, it has transpired to me as one of the great rectifiers across all those comparisons. Not the one and only. But one out of a small handful that I’d put on my list rolling rectifiers. It’s always struck me that the one application it’ll fit like the proverbial glove is in conjunction with the Takatsuki 300Bs, though. And yes, it’s not cheap.The Tak 274B rectifier is around $1400. I saw others including PSvane for a fraction of the cost. Does anyone have any experience with other 274B tubes? Can you explain the differences other than $1300 dollars more.
No adapter for KT170 and 5687 to 6SN7 (wooaudio or Chinese ones)So I did just order a 4 piece set of Tung Sol Kt 170 (new) and a pair of Thomson CSF 5687 (used, "measuring like new") for my Horizon (to be delivered in September, probably) for reasonable prices.
What kind of adaptors will I need if any?
Thanks for help
Charlie
Make sure you get a Takatsuki 274B rectifier. I can't stop listening to mineSo I did just order a 4 piece set of Tung Sol Kt 170 (new) and a pair of Thomson CSF 5687 (used, "measuring like new") for my Horizon (to be delivered in September, probably) for reasonable prices.
Thanks for help
Charlie
What would be the lifecycle? 1-2 years?Make sure you get a Takatsuki 274B rectifier. I can't stop listening to mine
In a DAC? Why should it be so short? Unless the reservoir capacitor exceeds 4µF (would have to ask Lukasz)?What would be the lifecycle? 1-2 years?
I´m not ready for that kind of money burning just yet.
Maybe later this year though...
I don´t know, I was actually asking. I know that the other tubes are driven well below there specifications and Lucas claimed a life span of 20 years for them - but what about the rectifier tube which is working full power all the time? Or is it not?In a DAC? Why should it be so short? Unless the reservoir capacitor exceeds 4µF (would have to ask Lukasz)?
Greetings from Switzerland, David.
Just ordered from Wooaudio. Thank you.5687 to 6SN7 (wooaudio or Chinese ones)
The Takatsuki, as far as I know, is a straight copy of the legendary Western Electric, with the exception of using thicker glass. The specification for the WE 274b reads the reservoir capacitor to be used must not exceed 4µF. While it’s otherwise interchangeable with 5U4G (maximum reservoir capacitor 40µF), using 274b with a larger than specified reservoir capacitor may drastically shorten its lifespan.I don´t know, I was actually asking. I know that the other tubes are driven well below there specifications and Lucas claimed a life span of 20 years for them - but what about the rectifier tube which is working full power all the time? Or is it not?
( I cannot follow your technical remark about the capacitor as I´m incompetent, sorry.)
Greetings from Germany, Charlie
