Too easy Elliot. In a perfect world, the best word I can think of for all 3 of these would be...inexpensive!What words fit that perfect meal, the great bottle of wine, that amazing sexual encounter?
I think the best words I can hear Marty is they are on you!!! LOLToo easy Elliot. In a perfect world, the best word I can think of for all 3 of these would be...inexpensive!
Al, i appreciate the compliment, thank you.Mike your writing skills surpass both your digital and analog. to read your posts is like a new bistro menu. I’m not sure what it all means but I want to hear it.
I always feel digital is very much like sausages. They can taste very good but I really don't want to know how they are made.....Peter, you never ask easy questions.
1---copper LAN in my house and barn, broadband cable into my home.
2---2 Synology mirroring 'file backup' NAS's, 30tb each, one in the house, one upstairs in the barn--same for MSB and Wadax. neither of these is in my signal path, as my files are resident on my Wadax server, as well as were resident on the Extreme server.
3---Netgear ethernet switch upstairs----with the MSB i also used fiber optic interface (with 2m Sablon Ethernet cable) which plugged downstairs into my Extreme server until the last few weeks when (Emile then suggested) i used copper CAT6 to go directly to both the Extreme and Wadax servers from the upstairs switch.
4---now with the Wadax'--Nordost QNET switch with Qsource power cable and Qsource LPS, Sablon 1.5m Ethernet Cable + brand ??? Ethernet cable also being demo'd, this now into the Wadax server.
5----Wadax Ref Server and Wadax Ref dac w/dual power supplies + the Akasa Optical interface; all this sitting on RevOpod footers + Taiko Daiza's. using Stage III Gorgon XLR interconnects from the dac to the dart pre.
6----Nordost Qpoint synergy devices + power cables plugged into the Nordost LPS under each Wadax chassis.
i do have 4 power cords plugged into my 'clean' Equi=tech power related to my digital; two for the power supplies of the dac, one for the server, and one for the Nordost LPS.
the music management software (Roon) resides inside the server, as do the streaming sources, in my case, Tidal and Quboz.
an i-pad or phone is typically used to navigate the music management software. analogous to a CD player remote.
objectively step by step.
broadband---->modem---->switch----->in-home network---->switch--->ethernet cable--->maybe another switch + linear power supply --->ethernet cable---server---> interface cable (USB/Optical/?)--->dac---->interconnects--->analog preamp.
some people use wifi to source their ethernet, it's not hard wired.....many steps above can be skipped. OTOH some people 'stack' network switches to increase the effect.
keep in mind most network stuff is cheap, cheap. even nice switches are modestly priced relative to our analog gear. it's only dacs and servers where 5 figure price tags come into play.
not sure all that helped with clarity.![]()
Amen to that. The end result as to what hits your ears is all that matters.<snip> i'm into joy through consuming, not as much the why or the how.
I have always hoped that some day state of the art digital would sound in certain key aspects as good as or even better than state of the art analog. In particular in top notch audio systems with an extremely low noise floor the inherent ‘noise’ of analog replay - I suppose created by the stylus in the groove - is not ‘ideal’. One of the interesting aspects in the review of RH in TAS is that he explicitly mentions that the Wadax reference combo with Akasa cable recreates a bass performance that he has never heard before from any format, digital or analog. That is real progress imho.FYI there is in the current TAS April a report on the Wadax Server by Robert Harley
you can always buy a stand alone CD/SACD player; which can sound superb. super simple. silver discs. but multi-millions of files are then not at your fingertips. the degree of complication is a choice.I always feel digital is very much like sausages. They can taste very good but I really don't want to know how they are made.....![]()
I made that decision many eons ago. Haven't had a CDP for more than 10 years.you can always buy a stand alone CD/SACD player; which can sound superb. super simple. silver discs. but multi-millions of files are then not at your fingertips. the degree of complication is a choice.
Ok. I was considering buying a Wadax server to work with my MSB Ref DAC. I guess this is a bad idea and I will pass since you also think that one either needs to buy both together or not bother.I agree I think to many expect everything to be compared to everything. I am really not sure what is the point and purpose of this. These items are designed to be used together. Imagine if every part of every car was to be compared before someone buys. There is a total lack of trust and respect IMO for the companies that do the work and design the gear. Would you pull out the parts of your speakers and compare? There is a limitless amount of things one could do but these will only lead you away from the music not towards it. This is terminal audiophilia.
I know the Wadax guys for a while now and have many conversations about the products and what they want to achieve and you either take the trip with them or with someone else all of which are fine.
From a reviewer's point of view there is very little to be gained in doing that and at the end they have a business to run and make money as well.
You might wanna read RH’s review in TAS of the Wadax reference server. Although he is quite clear that using the Akasa cable brings the performance to an altogether different / much higher level, he is also very explicit that the Wadax reference server with an usb-cable is the best server he has experienced. Actually he is of the opinion that the Wadax reference server is an even more impressive achievement than the Wadax reference dac.Ok. I was considering buying a Wadax server to work with my MSB Ref DAC. I guess this is a bad idea and I will pass since you also think that one either needs to buy both together or not bother.
I disagree…I agree I think to many expect everything to be compared to everything. I am really not sure what is the point and purpose of this. These items are designed to be used together.
i tried both the Taiko Extreme server and Wadax server with the Wadax dac with USB. there is no reason that the Wadax server would not 'work' with the MSB Select II or Reference dac with USB.Ok. I was considering buying a Wadax server to work with my MSB Ref DAC. I guess this is a bad idea and I will pass since you also think that one either needs to buy both together or not bother.
Two min reasons why I have no CDP. Firstly streaming files or from a streaming service is good enough for me compared to spinning CDs. More importantly only space to keep one solid medium and Vinyl definitely has the edge with regards to SQ, ownership, artwork etc.Still spinning.
CD transport > Reclocker > DAC.
Have seen over the years the complication and drama of computer audio and the sonic vulnerability to minor changes in the chain, which can ruin it, in friends' systems and have zero appetite. Everyone makes the decision that suits them.
I am though interested in a small portable player with great headphones. That can sound really, really good; a friend has it. And it's simple. But it does not have multi millions of files at your fingertips. Nice to have, but I don't need that.
i almost forgot......ah yes, those 3 dials......Server has USB output for a reason and most important, 3 dials that haven’t been discussed here.
