Hello,
My second post here, appreciate your input
I'm debating between upgrading my DIN-RCA phono cable or rewiring my tonearm with AnalogMagik (link below)
My criteria in choosing best option by priority, assuming same cost for the 2 options:
- sound quality
- flexibility with multiple carts
- tonearm resale value
I'm currently using an Ortofon cable that came bundled with the tonearm
Cables I'm contemplating are Zavfino Gold Rush, Analyst Plus Apex Silver, Zu Audio Event ii
www.analogmagik.com
My analog setup:
Miyajima Destiny
Glanz MH-124s
Ortofon 6nx-tsw-1010
Gold Note PH10 and PSU10
Acoustic Solid Small Royale Turntable
Thanks
- sound quality
AnalogMagik Reference Phono Cable installed onto Glanz MH-124S Tonearm
AnalogMagik's philosophy for Phono Cable is to have a direct wire from Headshell Clips to RCA output without any breaks in between. The Glanz MH-124S can be fitted with a direct connection from Headshell Clip to RCA output using the AnalogMagik Reference Silver Tonearm wire.
My analog setup:
Miyajima Destiny
Glanz MH-124s
Thanks
