I think this has brought a lot of confusion. What Emile explained is that the OS update is about 75% of the total improvement, the other 25% is the USB Driver update.
cat6man,Will do cat6man. I’ll get a chance to try both later this week and will report back. Thanks
And how many % is the shift from fibre to copper? (Genuine qn, I have not been following that closely to the thread)...
Updated DAC profile list:
-Analog Domain DAC1 - USB2 - Roon 32-bit
-Anthem STR - USB3 - Roon 24-bit
-APL DSD-MR - USB4 - Roon 32-bit
-APL DSD-SR - USB4 - Roon 32-bit
-Aries Cerat Helene - USB4 - Roon 32-bit
-Aries Cerat Kassandra - USB4 - Roon 32-bit
-Aqua Formula xHD V2.0 - USB4 - Roon 32-bit
-Aqua La Scala - USB3 - Roon 24-bit
-Ayre QX-5 with USB2 upgrade - USB4 - Roon 32-bit
-B&O Beolab 50 - USB1 or USB3 - Roon 32-bit
-Boulder 2120
-Bricasti MDxx - USB4 - Roon 32-bit
-Brinkmann Nyquist - USB3 - Roon 24-bit
-CH Precision - USB3 - Roon 24-bit
-DCS Bartok - USB3 - Roon 24-bit
-DCS Rossini - USB3 - Roon 24-bit
-DCS Rossini Player - USB3 - Roon 24-bit
-DCS Vivaldi - USB3 - Roon 24-bit
-DCS Vivaldi Up-sampler - USB3 - Roon 24-bit
-DCS Vivaldi One - USB3 - Roon 24-bit
-Denafrips Gaia
-Denafrips Terminator Plus
-Devialet Expert Pro
-EMM Labs DA2 - USB3 - Roon 24-bit
-EMM Labs DAC2V2 - USB3 - Roon 24-bit
-EMM Labs DAC2X - USB3 - Roon 24-bit
-Esoteric Grandioso D1X (PCM only)
-Esoteric K-01X (PCM only)
-Esoteric K-01XD (PCM only)
-Esoteric K-03 (PCM only)
-Exogal Comet - USB3 - Roon 24-bit
-Goldmund Mimesis 20H Nextgen - USB3 - Roon 24-bit
-Gustard X26 Pro - USB4 - Roon 32-bit
-Holo Audio May - USBx - Roon 24-bit
-Ideon Absolute
-iFi Pro iDSD
-Lampizator - USB4 - Roon 32-bit
-LH Davinci MKII - USB4 - Roon 32-bit
-LH Virtuoso - USB4 - Roon 32-bit
-Luxman D10X - USB1 or USB3 - Roon 24-bit
-Matrix Audio X-SPDIF 2 - USB1 or USB3 - Roon 24 bit
-Meitner MA-3 - USB3 - Roon 24-bit
-Meitner XDS1 V3 - USB3 - Roon 24-bit
-MSB Pro USB - USB3 - Roon 24-bit
-MSB V / Quad - USB3 - Roon 24-bit
-Mutec MC-3+ - USB3 - Roon 24-bit
-Nagra HD-X - USB2 - Roon 32-bit
-Nagra Tube Dac - USB2 - Roon 32-bit
-Pilium Elektra - USB3 - Roon 24-bit
-Resolution Audio Cantata 3.0
-Sennheiser HE-1 - USB2 - Roon 32-bit
-Singxer SU-6 - USB3 - Roon 24-bit
-SoTM dx-usbHD - USB1 or USB3 - Roon 24-bit
-Soulution 330 - USB3 - Roon 24-bit
-Soulution 760 - USB3 - Roon 24-bit
-T+A MP 2500R - USB4 - Roon 32-bit
-T+A SD(V)3100 - USB4 - Roon 32-bit
-Thrax Maximinus - USB4 - Roon 32-bit
-Topping NX4DSD - USB4 - Roon 32-bit
-Totaldac - USB1 - Roon 24-bit
-Trinity 1st gen model - USB1 or USB3 - Roon 24-bit
-Trinity Reference
-Vinnie Rossi L2 - USB4 - Roon 32-bit
-Vitus - USB4 - Roon 32-bit
-Wadax Reference - USB3 - Roon 24-bit
-Weiss DAC-501
-Ypsilon 1000 - USB4 - Roon 32-bit
Hi Emile. Is it just a regular Cat 6 cable?Considered to be very significant.
Yes, a noticeable improvement, I changed to copper after followed Emile advise. I have been using fiber with outstanding results before moved yesterday with this update. It looks like the Ethernet card on the Extreme is a better match to this OS implementation.Those are pretty neutral, if you want to play around with others be my guest, but I do recommend to at least listen to a standard unshielded cable as a reference.
Emile,Updated DAC profile list:
-Boulder 2120
-Denafrips Gaia
-Ideon Absolute
-iFi Pro iDSD
-Trinity Reference
-Weiss DAC-501
Emile,
with MSB Pro USB and TAS only, do you still recommend USB3 profile?
thank you.
So, are you-all talking about both copper IN to Switch and OUT to Extreme?Yes, a noticeable improvement, I changed to copper after followed Emile advise. I have been using fiber with outstanding results before moved yesterday with this update. It looks like the Ethernet card on the Extreme is a better match to this OS implementation.
Aaaaahhhhhhh!!! Now we are “talking“. You’ re absolutely right, like always. Digging into the recording like never before.I’d expect USB4 to do best with TAS.
Does your DAC accept a copper Ethernet input?So, are you-all talking about both copper IN to Extreme and copper OUT to DAC?
I know for awhile the consensus was a mix of fiber and copper were ideal.
I have been using fiber (70' run) from router to Switch, and then copper from Extreme to DAC -- with very good results. Like Marcus Barkus, I'm a little reluctant to touch anything as it sounds so good now!
The new remote app will have an option to switch DAC profiles, AND an update button so you can all just hit the button in stead of having to grant us teamviewer access.
In my case is copper to the Extreme from a Melco S100 router (Using a Sablon Ethernet cable), the rest is a mixed of fiber and copperSo, are you-all talking about both copper IN to Extreme and copper OUT to DAC?
