Did U try the VT99?The one tube we didn't get to use was a 6ns7
No however this is supposedly a fantastic tube to use with the HorizonDid U try the VT99?
The Melz metal plates I've seen either have vertical rectangle holes or round holes. Are there some with "no holes"?The MELZ Russian Metal Plate with no holes was also found to be a magnific
We payed that a lot and it seems to be every bit as good as the 6900ent tube and doesn't need adapters
For what its worth, Topaz is not a good isolation transformer. If you want a real isolation transformer, you need a tripple insulated k13 from Controlled power at a minimum. Those medical Triplite are also junk. I have put scopes on both and distortion can be higher on the output than input. I have listened to both and they are not going to fix toroid core saturation hum. Speaket hum is a totally different conversation. Were talking the transformer itself, correct. An Isotek syncro will knock about 85% to 90% of transformer hum down too.I've heard this from several Lampi owners of comparable DAC's. My units have been sent out for upgrades and then evaluated for noise, and they are clean in other settings.
It seems that I have a power supply issue that challenges transformers more than most. I've applied Topaz isolation transformers (balanced and not), DC offset cancelers, and regenerators (best solution so far), but I still get some noise. I just seem to have some gremlins... So, I am sensitive to noise, and am hoping to hear of the relative comparison.
Yes. And according to Lukasz those without are the best. Mine have no holes on the platesThe Melz metal plates I've seen either have vertical rectangle holes or round holes. Are there some with "no holes"?
We know who the winner wasGreat thread. Very exciting. This is better than watching the returns come in live on election night!!
I'd say if the "no holes" are metal base from the 50s, and if the application is to use them as a preamp tube and not as a driver, maybe the two may be regarded as roughly equal in the sense that depending on the vintage, one will find a better pair of one versus the other. In general, however, the 1578 with holes are more expensive for a reason. Be sure not to pay more for a 6H8C (Cyrillic for 6N8S) without holes than with holes in the plate (see pic below, please note it is NOT mine and that I'm not in the tube-selling business), the price ratio should still be around 50% for the non-hole metal base 6H8C compared to the famed "Holy Plate", and that bakelite base non-holes are dirt-cheap for good reason. Apparently the change was made for good reason, by the way, which wasn't sound quality, of course, but heat dissipation. Hence what I said in the beginning, it may depend on the application. A DAC isn't the same as an amplifier.Yes. And according to Lukasz those without are the best. Mine have no holes on the plates
Picture please, when U can.Yes. And according to Lukasz those without are the best. Mine have no holes on the plates
No, because your input impedance is ALSO PER PHASE hence 600 is 600, periodIt's listed at 600 ohms per phase. I haven't noticed per phase in other impedance specs. Would that mean 1200 ohms total output impedance?
Steve, I think your phone's focus needs a little realignment
In the pacific the small tube is power supply role and not signal role. Besides 6n6p, you can use 6n30p, ecc182, 6900 and 12bh7. The latter three require adapters .Can this tube be used in the Pacific?
when we inserted the MELZ Metal Plate, Lukasz discussed this very thing with all of the attendees. He said many times you hade tap the tube the noise would stop. Lukasz also discussed that there is indeed one pin that needs a small amount of solder to solve the problem. Having said that the issue of one hole vs 5 holes was discussed and Lukasz did comment that the MELZ tubes he seeks out as he prefers them the most are the ones with NO holes. He was quite insistent that the ones with no holes are sonically superior and sound more organic than the same tubes with perforated platesHaving said all this, I'd like to add something prospective buyers of either might want to know: don't panic if you happen to have a noisy one! That may be due to the old solder having crystallized in one or several pins. Sometimes reheating alone will solve the problem, if not, re-soldering (heating one by one with a soldering iron adding a needle pin's worth of fresh solder, then brushing the pins clean with a soft metal brush), if that won't do, use a solder pump and replace the old solder altogether. Needless to say, there are audiophiles who swear replacing the old with silver solder will improve the sound.
No it was me trying to taks some fast pictures with everyone hovering around. Ill get better ones later. Everyone is still sleepingSteve, I think your phone's focus needs a little realignment![]()
