I don't have this transport and have not tried it.My understanding is that this transport was made to be used in conjunction with the SDR2000 DAC only. Has any one tried using it with any non-Spectral DAC's? If so, which one's and what were the sonic results? Thanks!
Thank you for your well intentioned response...I have read this previously and it suggests that via SPDIF and AES/EBU it will work with other DAC's. However, I recently purchased a used SDR3000 and attached it to my Lampizator DAC. On light vocal and acoustic music it worked wonderfully but any music I played that had bass, drums, or pronounced low end caused severe distortion. On my behalf, a former Spectral dealer reached out to their tech person who told him that the 3000 was designed to only work with the 2000 and no other DAC's. That seems to contradict their own info. Further, they don't do repair on the 3000 as parts are unavailable. I thought I would reach out here at WBF and see what experience others might have. If you have anything else that might be of help I'm all ears...What puzzles me is that it took less than 5 seconds to find this information. Was it hard to find, or somehow unclear?
All I can suggest is try the SPDIF and EAS/ECU to find out if they behave the same. That is curious about the distortion since it outputs a digital signal. Do other transports work ok with the same connection and cable? Have you tried a different cable?Thank you for your well intentioned response...I have read this previously and it suggests that via SPDIF and AES/EBU it will work with other DAC's. However, I recently purchased a used SDR3000 and attached it to my Lampizator DAC. On light vocal and acoustic music it worked wonderfully but any music I played that had bass, drums, or pronounced low end caused severe distortion. On my behalf, a former Spectral dealer reached out to their tech person who told him that the 3000 was designed to only work with the 2000 and no other DAC's. That seems to contradict their own info. Further, they don't do repair on the 3000 as parts are unavailable. I thought I would reach out here at WBF and see what experience others might have. If you have anything else that might be of help I'm all ears...
Usually, the ticks and pops are due to the clock setting. dCS configuration should use Sync Mode “Audio” as it does not have a word clock input.Used it with a dCS Dac in the past. Did not do well there (ticks and pops). But it is not fair to attribute this to the 3000. Ditched the dcs and spectral long time ago. Pro for the 3000: ergonomics TOP. Clear display. loved it for that. That said, I would not buy one now> too old. As transports are not dead, one wonders why Spectral doesn’t produce a new one?!
Thanks to your suggestion and that of a friend I consider an “audio Yoda” I tried another cable and the SDR3000 is working flawlessly with my Lampi DAC. I overlooked this obvious move as the cable that I was using worked well in the same capacity with other components. Lesson learned, try all available options! Thanks to everyone for your input and suggestions!All I can suggest is try the SPDIF and EAS/ECU to find out if they behave the same. That is curious about the distortion since it outputs a digital signal. Do other transports work ok with the same connection and cable? Have you tried a different cable?
Just thinking out loud...
Do you have any preferences regarding brand when replacing caps in the 3000?Agree with the above. If Spectral will not repair it I would.
1. First, try different digital output cables (SPDIF and AES) and see if the problem exists on both
2. As stated above...open the top and see if you see swollen capacitors. I think this is likely as I had this on my spectral CD player. If you see badly swollen caps then there are places around that can repair or completely recap the unit.
