E Elftrader Well-Known Member Jan 16, 2022 13 0 66 65 Jan 16, 2022 #1 Do i need ht bypass on a preamp when connecting mains from a processor preout to a preamp input? guess it means i will have 2 volume controls. any concerns?
Kal Rubinson Reviewer May 4, 2010 2,542 893 1,700 NYC www.stereophile.com Jan 16, 2022 #2 Elftrader said: Do i need ht bypass on a preamp when connecting mains from a processor preout to a preamp input? guess it means i will have 2 volume controls. any concerns? Click to expand... The HT bypass takes the preamp's VC out of the circuit. Reactions: Lxgreen
E Elftrader Well-Known Member Jan 16, 2022 13 0 66 65 Jan 18, 2022 #3 What if i dont use ht bypass, will it still work ok?
Kal Rubinson Reviewer May 4, 2010 2,542 893 1,700 NYC www.stereophile.com Jan 18, 2022 #4 Elftrader said: What if i dont use ht bypass, will it still work ok? Click to expand... You need to have a constant/fixed volume control setting on the preamp for this to work. That way the prepro controls will work properly.
M MTB Vince Well-Known Member May 11, 2019 190 223 148 61 Dundas, ON Canada Jan 19, 2022 #5 Are you running balanced XLR or single-ended RCA interconnects @Elftrader ???
