Thanks Mike.Shawn,
many thanks for the effort to do a compare like this. your write-up is very helpful. the idea of one server as a Roon Core and another as a Renderer being best is a concept i never considered. we can only guess as to why that might happen. i'm sure there will be considerable speculation.
i think your out-of-box thinking does allow us to view these pieces more objectively. i hope you do get another round with these pieces to get even deeper truths. again, thanks.Thanks Mike.
In fact this idea didn't come to me as a planned combo. When I just set up the Taiko with my own Roon account and Qobuz account, somehow the software didn't work till I reboot the Taiko. Before the reboot, I couldn't properly use the streaming of Qobuz when setting Taiko as the Roon Server. So I had no choice but to use Wadax as the server. It ended up with a super performance. I reboot the Taiko and everything goes normal, that I can use Taiko stanalone.
True that very rare chance for people to try separating Taiko as a renderer. At the cost, nobody wants to waste the money only to use it partially. But as I shared, I didn't use TAS, therefore I might have missed something. With TAS, the thing might be different. I'd have to find out when I can afford my own Taiko, and hopefully the Wadax is still around. But considering the combo cost, it is just crazy.
Thanks Mike.
Hello Shawn,I didn't have the chance to try TAS, the in-house software from Taiko. I'm a heavy Roon user and I misunderstood the TAS as a pure local file player and didn't realize it can integrate Qobuz and Tidal. Pity I didn't try it before I returned the Taiko. I read quite some comments that the TAS sounds better than Roon.
I do believe it is true, though I didn't believe it for a long time that an app can bring SQ differences. This recent conviction came from the use of Auralic Aries G 2.1.
I always likes a transporter with a screen which give me a better feeling when looking at the cover of the record I'm playing. That's the reason I wanted an Aries in the first place. I planned to use it as a renderer to Wadax core, without expecting it can improve the SQ.
When I replaced M5 by Auralic Aries, there was no good or bad surprise. They just sounded similar to my ears. Just the graphic gives me a good pleasure in playing the streaming musics.
However, after a few days of Roon, I randomly opened up the DS software developed by Auralic, not only using it to set up the unit but also using it as the player. I immediately noticed the improvements it brought to the Roon playback. The DS+Auralic gives a quite analog sound, fuller bodied, quite involving. I cannot say it easily beats Wadax+Auralic or even Wadax standalone but it comes to a similar level. I can live with a single Auralic with no complaints. It misses a bit of details and scale compared to Wadax (both separate and standalone) but the dark and analog sound it brings to the playback kinda compensates what is lost.
I do appreciate the Auralic Aries G2.1 when it is used with DS apps. This also "convinces" me that if I tried TAS on Taiko, it should have brought the performances of those combos above into a higher leve. By all means, Roon is designed to work with a lot of platforms while DS or TAS are specialized and customzied to their brands.
I heard from Edward Hsu of Taiko that the XDMS will be soon available on SGME. I belive that'll bring new improvements.
Mike, indeed Roon has always stated that separate core and renderer will provide the best sound quality, in fact it's their #1 recommendation on how to get best sound. The theory is that no matter how good the core computer is, it's still a complex electronic machine that generates much more noise than a renderer. Therefore it makes sense to isolate through a well thought-out network setup. Of course once you get to the level of the Extreme, only personal experimentations will tell for sure.Shawn,
Shawn, thanks for sharing your journey. Auralic is a great piece, if you decide to stay with it, may I suggest looking at the power supply upgrade from Germany. I have the Aries G2 and it provided a big improvement to the ease, polish and dynamics of the sound.I didn't have the chance to try TAS, the in-house software from Taiko. I'm a heavy Roon user and I misunderstood the TAS as a pure local file player and didn't realize it can integrate Qobuz and Tidal. Pity I didn't try it before I returned the Taiko. I read quite some comments that the TAS sounds better than Roon.
....... and a slightly newer link:Shawn, thanks for sharing your journey. Auralic is a great piece, if you decide to stay with it, may I suggest looking at the power supply upgrade from Germany. I have the Aries G2 and it provided a big improvement to the ease, polish and dynamics of the sound.
Thanks for that, I wonder what the improvements are on the newer version, i see the transformer is different....... and a slightly newer link:
Matt
Shawn,
Sorry for my ignorance, but is this similar to using the JPLAY dual PC setup - with dedicated Audio PC fully optimised for music transport and Control PC is your music server (where your music files are stored)?
Hi Emile (I guess),Hi @ShawnZH ,
Thank you for reporting on this comparison. The Kalista has not been added to our USB driver support as we've had no customers using one yet. Did you install a Vendor (Kalista) supplied ASIO driver for it or did you use the generic windows support ("wasapi" and/or "system output" in Roon)?
