Thanks very much.There is a LED at the front of Grand Master. I was told that this LED is purely decorative.
The main LEDs are located at the back of the cartridge. The light you see is reflection from vinyl surface. View attachment 83893
Hmm, just checked that the compliance of the GM is lowish medium at 11/14 while the Thales Statement is high-ish medium effective mass at 24g. Should be quite compatible right ?Koetsu matches well with FR64S which is a heavy arm. Grand Master is only 7 grams, it should match with a light arm. Thales is not light enough. You are not revealing the full potential of Grand Master.
As I said, not Thales is not light enough for Grand Master.Hmm, just checked that the compliance of the GM is lowish medium at 11/14 while the Thales Statement is high-ish medium effective mass at 24g. Should be quite compatible right ?
And grand master is a good match with Sat?As I said, not Thales is not light enough for Grand Master.
For cartridge in this caliper, correct compliance matching pays real dividend. In fact the weight of cartridge gives you an idea the arm that it matches. Light cart is for light arm, etc.
SAT is the only really good light weight tonearm in the market. It matches perfectly with Grand MasterAnd grand master is a good match with Sat?
Durand Tosca (Gimbal design very similar to the SAT) seems perfect for my 8 gram (very light weight) Etsuro Gold. i view it as a 'really great' light weight tonearm. jazdoc uses the Etsuro Bordeaux (also 8 grams) on one of his Tosca's. Jonathan Tinn (distributor of darTZeel, and other products) has run a DS Audio on his Tosca.SAT is the only really good light weight tonearm in the market. It matches perfectly with Grand Master
This is correct. I do have the Thales arm but only the DSAudio W2. I informed the manufacturer of DSAudio that although it can be done it’s a difficult match and I wouldn’t recommend.Koetsu matches well with FR64S which is a heavy arm. Grand Master is only 7 grams, it should match with a light arm. Thales is not light enough. You are not revealing the full potential of Grand Master.
The W2 has a red light the entry level E1 has a green lightThanks very much.
I thought Durand Tosca is regarded as medium weight arm. It matches well with Etsuro Gold, no doubt, but it should be better with a lighter arm.Durand Tosca (Gimbal design very similar to the SAT) seems perfect for my 8 gram (very light weight) Etsuro Gold. i view it as a 'really great' light weight tonearm. jazdoc uses the Etsuro Bordeaux (also 8 grams) on one of his Tosca's. Jonathan Tinn (distributor of darTZeel, and other products) has run a DS Audio on his Tosca.
Wave Kinetics NVS Turntable, Durand Tosca Tonearm, DS Audio DS Master 1 Optical Cartridge, EQ/Phono Amp, DS Audio ION-001 - Positive Feedback
Impressions: The Wave Kinetics NVS Turntable, Durand Tosca Tonearm, and DS Audio DS Master 1 Optical Cartridge and EQ/Phono Amp with the DS Audio ION-001positive-feedback.com
i have 2 Tosca's and each has an Etsuro Gold. i have no experience with the DS Audio cartridges. Mik in the UK (member 108CY) has had DS Audio in his system , had (has?) an SAT in his system, and owns a Tosca; you could ask him about it.
Many thanksSAT is the only really good light weight tonearm in the market. It matches perfectly with Grand Master
I use a Thales AV arm with my DS Audio cart. It took a while to set it right, not an obvious match i grant you, but now it absolutely sings.As I said, not Thales is not light enough for Grand Master.
I was given a discount, about 50% off the standard price, that’s allNot under warranty? Sheesh!
sorry to hear that. ouch!I was given a discount, about 50% off the standard price, that’s all
I've had my Grand Master cartridge and demo DS-EQ1 equalizer set up for over a week now, and it's been a game-changing part of my audio journey. The vinyl removes a layer hiding the sound, leaving a clear picture of the music, the musicians, and the soundstage. Very natural but still detailed, wonderful imaging, completely non-fatiguing. Clearly beats my transport (which in turn clearly beats my music streamer).
This cartridge/equalizer has already converted me into a vinyl-first music listener, though I can still *enjoy* good discs and some streaming. My business partner (primarily listens to 30IPS 1/2" R2R) came over to listen last week, his summary: "Reference quality, especially with good vinyl. You could live with this system for the rest of your life." Another audiophile friend came over yesterday, his text afterward: "That phono experience broke my brian. Unreal!"
I have a DS Audio equalizer (I think DS-W2) arriving this week so I can compare the two. Perhaps the first equalizer shoot-out? I'll report back soon.
RonR and MikeL: Thanks for taking the time to talk to me. I appreciate your thoughtful and helpful conversations along the way.
I can't believe I waited this long to add vinyl to my system.
I'm thrilled!
