he is close to perfection, engine, chassis characteristics and designThe V10 I like most is Audi R8. It's been my dream car for years.
I'm bmw guy I find it hard to say, but it's the truth.
Like i said before i hope your mtsl studer " upgrade " doesnt sound like the mtsl tape i bought.I think this thread is discussing the best sources in absolute terms regardless of time right now honestly![]()
Did you try upgrading your 810/812 internal boards yet? I just did MTSL courtesy of support from Leif and was quite dramatic.
But what if one has the A80 with FM heads and Doshi!!I realize the tape handling is better on the A80 and 820, but I don’t think either produce the same level of playback quality that the Doshi preamp plus FM head does.
I haven’t and I guess at this point I won’t since the Technics/Doshi is my main playback deck. Who builds the boards for the 810?
Typical butterfly heads damage the imaging for the sake of better SNR figures, so I try to avoid them if possible. The FM heads have wide guard track, which is good, but... they also, in my opinion, fall short of the Otari MTR heads, that combine the best features of both - they are butterflies with wide guard band.what will the FM heads do compared to the Studer butterfly heads?
from 1993...is it even analogue?
wiki says it was recorded at Blues Alley in the US
Technically I don't know what it does. But sonically I am very glad I changed the head. In my case the clarity is improved over the studer head that I had on before. The frequency response is better more linear and extended. If your Studer butterfly head is better than the one I had, my comment might not be relevant at all. But I would recommend tape people to try it, since the cost of replacing is much less than a new cartridge or some fuse.what will the FM heads do compared to the Studer butterfly heads?
FWIW, my combination of Technics RS-1500, Flux Magnetics head and Doshi EVO tape preamp sounds much better than either my Studer 810 or 812,
Dont forget studer C 37 studer A 80 and the Studer B62 which was the portable on location version of the Studiomachine the A 80.a little question, why is nobody using an Ampex 351 or a Telefunken M5. this is how the best recordings of classical music have been made. excellent tube head amps are also on board
Ampex 351
Telefunken M 5c
the audio boards are 1: 1 interchangeable. the b62 is a mobile reportage version of the a80. the b62 was only built in 1972. c37 from 1961-1970Dont forget studer C 37 studer A 80 and the Studer B62 which was the portable on location version of the Studiomachine the A 80.
All the people shitting on stock studers are also shitting or their own beloved " best of the best/ those were the days of analogue " 50 s 60 s 70 s LPs
This is similar to Myles' right? That was an extremely musical tape set up. Imho that was more emotionally gripping for me than any Studer etc set up that I have been played. I am unable to say if it was a combo of Doshi, FM heads, or what, but what you say links that up nicely.
You speak with such conviction, so just one question: have you done such a comparison yourself? Please, no "How the records are made" nonsense, just holding a modern tape in your hands, have you played it two ways: trough the internal electronics and then through a good head preamp?All the people shitting on stock studers are also shitting or their own beloved " best of the best/ those were the days of analogue " 50 s 60 s 70 s LPs
Nobody shitting on stock Studers andro. I think the tone people used commenting on stock vs non-stock and discussion on this thread so far is polite enough non sarcasm no where near the tone many used to comment in Wilson and Magico thread. Also Why would everything from 50s 60s are best of the best. Todays audio is best of the best too imo. Only up to who is listening.All the people shitting on stock studers are also shitting or their own beloved " best of the best/ those were the days of analogue " 50 s 60 s 70 s LPs
