First one.Power can be fixed with Kagura, room
I just bought Iranian wall tapestry to try to improve the room.
Help me pick one please, my taste is a bit off
I’ll move my OB further away, perhaps 1-5-2 m from walldepends on crossover frequency...i asked earlier remember
I am not saying it needs to change but open baffle at high volume needs a lot of woofer area!
No room treatment that can help except making the room bigger? I don’t mind spending lots of money to fix my room if I can avoid tearing down my room. Too noisy and stressfullPower can be fixed with Kagura, room???
I doubt it will be powerful enough. Nice sounding for sure but not powerful enough.
I have a rug from Iran between my speakers, also silk. I wish I had bought a few more when I was there...I ended up buying this, coming in 30 min as I forced my regular tapestry seller to delover it himself. Damn thing expensive $8300, silk handmade I hope it helps a lotView attachment 85257
What do you think? Awesome or too expensive?
Awesome.I ended up buying this, coming in 30 min as I forced my regular tapestry seller to delover it himself. Damn thing expensive $8300, silk handmade I hope it helps a lotView attachment 85257
How big is your room right now?No room treatment that can help except making the room bigger? I don’t mind spending lots of money to fix my room if I can avoid tearing down my room. Too noisy and stressfull
Congrats.New update. Just called my dealer and ordered Kagura and G1000i, they said Kagura V1 is slow as molasses and Kagura V2 is Ongaku on steroid. Will be delivered March 2022…. Can’t wait.
4.8m x 8.5m x 3.2mHow big is your room right now?
Holy Moly. Congratulations!New update. Just called my dealer and ordered Kagura and G1000i, they said Kagura V1 is slow as molasses and Kagura V2 is Ongaku on steroid. Will be delivered March 2022…. Can’t wait.
It’s addictive, bery very exquisite. I have 7 all very niceI have a rug from Iran between my speakers, also silk. I wish I had bought a few more when I was there...
It’s a good size room. Although I don’t see a point to crank up to 120db, I imaging you need a much more powerful amp. Maybe show us your room so we can find how you can treat your room.4.8m x 8.5m x 3.2m
If you hang it to the wall, make sure it hangs with a 10 cm air gap from the wall to be most efficientI hope it helps a lot
Those are my very ampsWow.
Wonderful room size.4.8m x 8.5m x 3.2m
