To Equalize or Not to Equalize: That Is the Question
tmallin
WBF Technical Expert
May 19, 2010
974
390
1,625
71
Chicagoland
There is no doubt that most commercially available recordings have been subjected to electronic equalization (EQ) at one or more stages of the recording/production process. However, for more than a generation, audiophiles were highly averse to applying any such electronic EQ in the home listening room. Any equipment which had serious pretentions to being "high end" at least had to have defeat switched on the tone controls, and mostly such controls were entirely banished.
But since the dawn of the current millennium, at the "What's Best" level of audiophilia, as well as among home theater devotees, there has been a slow increase in recognition that the availability of electronic EQ in the home music system can be helpful--at least sometimes and for correcting some problems. Some have jumped in with both feet and unreservedly trust DSP-based speaker equalization, DSP-created crossovers, and DSP room correction to bring them closer to audio heaven than is possible with "old fashioned" analog electronics with minimally complex signal paths. Others are not so sure.
The Goal of Equalization
Assuming you want to use some form of electronic equalization, how do you learn how to use that equalization to improve the sound of your system? Now, anyone, even a child, can fool around with a software program, or twiddle knobs and sliders on an "old fashioned" analog equalizer and change the sound of an audio system in a few seconds.
It is less trivial to be able to reliably make electronic equalization changes which you think "sound better" to you. Oh, it may be fairly easy to make one bit of program material sound better. It may only take a few minutes for a novice. But change to a different track or different type of music and you may find yourself less sure.
Some folks go to the extreme of developing a number of customized "target curves" and labeling each track to indicate which equalization approach sounds best with that track. Some folks actually apply their favorite-of-the-moment equalization for that piece of music and save an equalized version as a file in their computerized music software library; the wiser of these folks don't discard the unequalized version.
The problem with this "sounds better to you" approach is that it is not transportable. Not transportable from system to system, listener to listener, track to track, mood to mood, or sometimes not even from moment to moment. Change something--anything--about the system, the set up, the room, or the listener and all your careful choices may go out the window. For some careful listeners who are actually more interested in at least sometimes being able to just listen to music rather than fiddle with adjusting the equalization, this is enough to cause them to give up on trying to apply electronic EQ to their home listening.
Others, seeing this peril, settle on single or very few target equalization curves which they or some trusted expert in their lives have developed and more or less just "set it and forget it." When I use electronic EQ at all, I tend to fall into this category.
Still, the question remains as to how do you know when you are making progress? Some folks think they just know when a music system is more life-like. They claim to have the sound of an orchestra playing in their head. Audio designers Bob Carver (Carver, Sunfire) and Arnie Nudell (Infinity, Genesis) have claimed this about themselves. For such folks, accurate musical reproduction is like some judges talk about pornography: they know it when they see/hear it.
Then there are those who just know the way they like their music to sound and they apply equalization of a fairly heavy-handed nature to make sure that most everything they play will have that sonic flavor--say, for example, lots of bass and lots of high frequency "air." There are potentially as many flavors of "sounds good to me" as there are people setting up electronically equalized home audio systems.
Then there are those who want "flat response" from their systems and are willing to live with the unvarnished, naked truth about any program material, even if they have to grit their teeth to bear it. They seek "the truth" about the recording and are willing to listen through any unpleasantness to hear that truth. They also seek maximum differentiation in the sound of various recordings, believing that the more the sound of recordings vary, the more truthful their system must be in reproducing exactly what is on the recording.
Another type of EQ user is the one who wants the sound of music, tonally speaking, to mimic to the greatest possible extent, what one would hear at a live unamplified concert in a good hall. I tend to fall more into this category than any of the others, I think. One way to be able to move your system sound toward such a goal is to attend a lot of such concerts so that you have a decent aural memory of what various instruments really sound like. That's me.
How I Learned to EQ
I have had more experience with a variety of EQ systems than most audiophiles, I think. I also have more experience using EQ to help match a known sound than most audiophiles. In a past life, for about a decade I worked with and eventually became the head of a volunteer technical production crew of a large church I attended, recording and amplifying voice and acoustic music in the sanctuary using fairly high quality equipment worth more than $250,000.
If you are amplifying familiar voices, as I was, you have an absolute reference point in that room. You know how the voice should sound in that room talking to the person close up. All you have to do is make that voice louder so it sounds from 50 or 100 feet away like it does when you are only a couple of feet from the person as the person talks to you without amplification in the same room. You sit at the mixer and play with the controls until you get it sounding about right. You soon learn what various controls do and what needs to be done to get accurate sound.
You can then apply the same technique to amplifying musical instruments in that room: listen live up close to a solo instrument or group--everything from a solo flute, violin, or harpsichord, to a piano to full orchestra or various vocal groups or full choir, and then get as close a match to that sound through the PA (public address) speaker as you can. This was possible since the instrumentalists and vocalists always were practicing when I was setting up mikes and other equipment close by on stage.
Dips are harder to hear in all frequency ranges than peaks and are therefore less worth worrying about. I should mention, however, that a decent PA mixer operator will try very hard not to have a dip in the midrange if speech is involved since any dip there will drastically reduce intelligibility and presence of the voice, making it sound hollow and distant as well. The type of EQ which may work wonders in terms of desirably "backing off" the sound of a full orchestra in your listening room sounds amateurish with live amplification of a speaking voice in an auditorium.
Equalizers I Have Known at Home
I do not pretend to know all there is to know about the merits of electronic equalization or about the merits of the various systems for implementing such equalization at home. For one thing, I have not (yet) used Acourate, which many EQ devotees believe to be the best such system currently available in terms of sonic results. But I believe that most who use it would also admit that Acourate has a very steep learning curve and is best used in the context of a hard-drive-based music system, which mine is not (yet).
I applied what I learned "on the job" to my home music system. The first two equalizers I owned were the Cello Palette Preamplifier and the Z-Systems rdp-1. These were generally acknowledged as two of the most transparent (in terms of not doing anything to the sound other than the intended EQ) such devices of that time and are still so regarded. The Cello used an analog six-band graphic EQ scheme developed by Mark Levinson (the man's) guru, Dick Burwen. Last I checked, the Z-Systems is still listed in Stereophile's Recommended Components and was a parametric digital preamp/equalizer. I wrote my comparative thoughts about the Cello and the Z-Systems in Audio Review back in 1999.
I could have stopped with the Z, but as audiophiles are wont to do, with system changes I eventually began to hear (or imagine I heard) a certain digital sterility, edge, and brightness to the Z-Systems sound. Even so, I was still convinced of the merits of home EQ. Thus, about the time I got my Harbeth M40s in 2004, I moved to an all-analog parametric EQ device, the Rives PARC. Sonically, I never heard anything wrong with the Rives, but it was not very flexible and was limited to correcting at most three bands of frequencies below 350 Hz, leaving me with no way to control the peaky highs of, say, old Mercury Living Presence recordings.
Thus, I eventually moved on to a professional equalizer of 30-band 1/3-octave digital graphic design, the Rane DEQ-60L. It was very flexible (all those bands, adjustable by channel) and was very easy to use (mechanical sliders with little interaction among adjacent sliders). Unfortunately, I heard sonic problems which I attributed to its A/D - D/A path (or imagined I heard--other owners hear no such problems with this unit) and quickly got rid of it.
I traded it for the all-analog Audient ASP231 31-band 1/3-octave graphic equalizer. This had all the flexibility of the Rane and all the sonic purity of the Rives, but unfortunately was a pain in the butt to adjust since it had LOTS of interaction among adjacent bands of adjustment. I soon tired of the hassle.
Having read many favorable comments about the TacT RCS units, I conquered my fear of computer-assisted equalization and purchased a TacT RCS 2.2XP AAA, which I still own. I shouldn't have worried about the computer-assisted part; I found the program, while buggy, to be reasonably easy to use.
Among the good points about the TacT is that the corrections it applies really can help with system balance, and thereby help solidify imaging and staging. Thus, despite the heavy-duty digital processing to which all music is subject, the subjective staging and imaging are about equal overall to a decent analog preamp like the Bryston BP-26 I also had when I bought the TacT, plus the best mechanical set up you can muster. I'd give the Bryston the edge in terms of stage depth, size, and ambient feel, but the TacT was not far behind in those respects and had the edge in terms of unwavering instrumental placement.
The TacT also allows full digital electronic crossover adjustments between stereo subwoofers and main speakers with a wide range of slopes from first to 18th order. In addition to minute correction of response to conform to a target curve of your choice or design, the TacT also offers 12 bands per channel of parametric EQ, as well as an interesting Ambiophonics-mimicking function.
The TacT's computer display is very informative and running response measurements, while a bit tricky to get best results, are relatively straightforward. You can guild the sonic lily with a better measuring microphone, feeding it pure power, damping the chassis, playing with the delay applied to the main speakers, and (by all user accounts--I don't use them) with after-market part swap outs from Maui Mods.
But there are some flies in the TacT ointment:
  • The subwoofer/main crossover adds a bit of glaze and brightness to the sound, especially when used with slopes greater than 4th order (24 dB/octave).
  • The software, as I mentioned, is buggy, and has been so from the start. This has actually gotten worse with the latest V1.0 beta software. That's a shame since the V1.0 software does sound a bit better. For example, I cannot get the beta software to simultaneously correct my subwoofers and correct the main speakers above 10 kHz. Others have no such problem, but have other problems I don't seem to have.
  • The Ambiophonics software, although entertaining and initially enthralling, is highly colored in terms of frequency response. You cannot simultaneously apply EQ and use the Ambiophonics processing, resulting in bass and treble heavy sound when the Ambiophonics processing is used.
  • The frequency response after TacT correction, measured with other measurement software, is not nearly as conformed to the target curve as the TacT's own computations or measurements show.
  • Check out on-line comments about TacT's recent level of customer support if you are thinking about buying a TacT unit.
What I Think I've Learned About Applying Electronic EQ at Home
The usual caveats about these being my current impressions subject to drastic revision later and not being transferrable to other users or systems apply. But I HAVE been around the EQ block a few times now and I think I've garnered a few nuggets which can help others down the path:
1. First and definitely foremost: electronic EQ at home works best when it has the least to correct. Exhaust all mechanical and set up tricks first before applying electronic EQ. I cannot stress this enough. Mechanical set up has no chance of introducing any kind of electronic distortion. EQ is not a cure all. It will not help or cure room reflections at mid and high frequencies. It cannot fill in severe dips in frequency response without stressing amps and speakers and generally lousing up the sound in the room no matter what your measurements say. EQ cannot correct for inherent distortion in speaker drivers or material colorations in the drivers.
2. Electronic EQ works best at bass and lower midrange frequencies, meaning below 500 Hz or so. Some would say below 300 Hz and I won't argue. At such frequencies, what you see on your frequency response measurement graph is what you audibly get, moreso at least than higher up. Higher up, electronic EQ is more problematic because it predominantly EQs only the direct sound from the speakers, not the room sound which is part of what you hear but progressively not part of what the microphone measures as frequency increases. It is better to control the room sound--sound bouncing off room surfaces--with passive acoustic absorbers (foam or fiberglass, typically).
Even when just applied to the bass, I would say that, in most cases, if you try to EQ your system so as to achieve a ruler flat bass response, even when extended to below 20 Hz, the result will sound a bit thin. You may find that the addition of anything from .5 to 3 dB or even more extra measured bass is necessary for proper subjective bass weight. You can do this either by adjusting your target curve to be "up" a bit at all frequencies below, say 200 Hz, or by not fully knocking down measured peaks in bass response, but only reducing them by about 70% of their peak value. A 10 dB peak could be reduced to a 3 dB peak, for example.
3. You should NEVER attempt to fill in significant (more than 2 or 3 dB) dips in frequency response in the bass or elsewhere via electronic EQ. It sounds bad and strains both amp and speaker.
4. Given the way commercial recordings are recorded and produced, with most speakers and most music, if you are attempting to mimic the sound of live unamplified music in a concert hall (and probably even if you are just adjusting the sound to "sound better" to you) you will end up with a target curve which generally slopes down in level by 4 to 10 dB from bottom bass to highest treble. The preloaded target curves which come with the TacT are almost all of such a shape. Almost all individually constructed target curves end up with such a shape. How much of a drop from bass to treble will sound correct to you depends on your individual taste, your set of reference recordings, your sonic goal, your speakers, and your room. In very general terms, the narrower the high frequency dispersion of your speakers, the less drop you will likely want to apply to the measured on-axis treble response. You may also find that inserting a bit of a dip in the response between 2 and 6 kHz (while anathema to live sound reinforcement) will be helpful with many speakers on much recorded material.
5. Since EQ works better in cutting back on bass response peaks than in filling in dips, you should buy your speakers wisely. Buy speakers that seem, if anything, overly generous in many rooms in bass response. You do not want to buy speakers which have "tight" bass in most dealer demos. By buying generous-bass speakers, you can be more certain that when you get them home and EQ them, you will basically only have to cut back on bass response, not fill in dips. Cutting back on bass with electronic EQ helps both speakers and amps to loaf along even at high levels, lowering distortion of both electronic and mechanical nature.
6. Never try to extend the ultimate low-bass rolloff with electronic EQ. That is the same as, or worse than, attempting to fill in dips in response. This strains amps and speakers and increases distortion in the bass and further up. If you want low bass, buy more capable speakers and/or add subwoofers.
7. I have found that it is better to buy speakers whose UNEQUALIZED midrange and highs sound great to you at dealers and in a home trial than to buy something you will need to EQ in that range. As mentioned above, equalizing above the bass gets problematic because the measurements frequently don't well reflect the subjective sound in the listening room.
With the TacT I almost invariably found that with the speakers which sounded best to me in the mids and highs, the best sounding target curve from 500 Hz on up was a target that just followed as exactly as possible the measured response of the speakers. The ability of the V1.0 TacT software to turn off the EQ above a chosen frequency is helpful; you can thus use it for only bass EQ if you like. Believe me, when the mids and highs sound as good as they do on Harbeth M40s or M40.1s, you do not want, much less need, to equalize them, at least with most material.
As an aside, I believe that it is getting harder rather than easier these days to find speakers with natural mid and high frequency balance when judged by concert hall standards. The tendency in recent years has been toward a brighter and more forward balance than is natural. You can see this in measured response tests in Stereophile, for example, within speakers of a given brand as years go by. While speaker drivers have improved greatly over the years in terms of lowering distortion and improving power handling capability, the designed-in overall frequency balance has, if anything, deteriorated significantly. I know of no currently available speakers, for example, which in an ordinary listening room with little or no special acoustical treatment and when positioned out of the way flat against a wall can match the mid-hall naturalness of vintage Acoustic Research speakers such as the AR-3a and AR-5 manufactured around 1970. Harbeths can sound better than the ARs due to their superior modern drivers, but they need "audiophile" set up to do so, with careful out-in-the room placement and/or EQ to tame the warm bass and room treatment to absorb off-axis room reflections in the mids and highs.
8. Broadband correction sounds better than micro-correction, at least above the bass, and on most days I'd say even in the bass. Thus, something like a 1/3-octave graphic EQ or adjustable parametric will actually sound better than the type of micro-correction of which the TacT is capable when applying its target curve. Thus, for example, the TacT results sound better when just applying the 12 parametric bands of EQ than when using the target curve function. One-third-octave bands relate to how our ears average sound levels and thus have plenty of resolution to give optimal results.
9. The best EQ devices should have a great deal of flexibility. You don't want to be locked in to some single (or even a few) automatically chosen EQ curves. The automatic ones usually sound too bright and not full enough in the bass. This means that products like RoomPerfect and Audyssey are out, as far as I'm concerned, unless in the particular implementation, they can be combined with some type of graphic or parametric EQ, as in some AVRs and pre-pros. An electronic EQ device which is limited to just working on the subwoofer's output is not flexible enough. If the subwoofer is being used properly, its output will be rolled off above 80 Hz or even lower, while bass room modes may need correcting up to 300 Hz or so.
10. Some of what you may think you need EQ for is just the product of poor quality digital front end components. Most digital playback still sucks. Once I got my PS Audio Perfect Wave Transport and DAC, I found that much of the annoyance I was trying to correct for with EQ simply vanished. Sure, some recordings made with peaky old mikes still sound too bright, but the brightness is not accompanied by any nasty edge and is much easier to just accept and listen around. Bass firmed up and a degree of relaxation became apparent that just removed many barriers between me and the music. Definitely, YMMV, but, for me, the change wrought by this digital front end change was more important to musical enjoyment than any EQ I've ever used.
11. Not strictly EQ related, but relevant: Even if you have subwoofers, you usually will want to confine their response to the low bass. Yes, you can get good results by mating mini-speakers to subwoofers with a typical THX 80 Hz 4th-order high/low pass crossover, but you will probably get yet better results by using more bass-capable main speakers and rolling your subs out at 40 to 60 Hz. Many speakers, and the Harbeth M40 and M40.1 are among them, sound best when allowed to play down to their natural roll off point and sound less like themselves when rolled off above that point. As a common example, many Quad speaker enthusiasts are tempted to roll off the Quads well above 100 Hz and pass off to the subs at such a high frequency in order to get more SPL capability from the system since Quads will play plenty loud in the midrange, but not the bass. But they find that you trade off some of the Quads' sonic virtues for the increased SPL. What bass a fine main speaker has will often sound better than a subwoofer reproducing that midbass range.
There is no doubt in my mind that my room would benefit from digital correction as well as helping me integrate ny X-2's with my two Gothams. My concern as has been told to me by several TacT users who corroborated that the above concerns would be improved BUT at the expense of the great mid range and upper frequencies delivered so well by Lamm
Hi Steve,
The Gotham has it's own built in EQ software doesn't it? Did you daisy chain the subs before calibration? I think that that would be the best way to calibrate a pair and not one at a time.
Jack
Greatly insightful Tom!
Most folks don't realize that fact that EQ is in there already. Anytime an engineer reaches for a mic EQ will soon follow because mics simply aren't flat.
I believe it was the proliferation of horrible graphic EQs in the 70's and 80's as well as user abuse of their functionality that caused a backlash against the home use of equalization. One far larger in effect than the "simpler is better" campaign. You simply were not a "serious" manufacturer is you had EQs like those found on the rack systems and mini-component boxes that were all the rage.
As with anything in our hobby, the end results are what matters most. I have a Lyngdorf RP-1 which I suppose you could call loosely the next generation of TacT. It takes multiple samples from multiple locations with their deleterious effect on bypass mode in the ballpark of having another extra meter of interconnect. Okay so I'm being humorous as one meter of interconnect sounds the same to me as two. :) I just couldn't resist the urge to throw that in there because cable length is another audiophile dictum that has cemented itself, even if it means putting a rack loaded with thick aluminum faceplates right between the speakers just to keep the signals as pristine as possible. Even folks that don't believe cables sound different follow this! Just to be clear I'm not knocking anyone with racks up front. Just those that have the luxury of relocating their rack but refuse to for the reason already stated.
Even I have that vestigial anti-eq tail and resort to acoustics and basic set up before turning to active signal manipulation. I do maintain however that these new DRC boxes work. No they are not silver bullets but for those that for practical reasons, like wives :) , have no choice, I would recommend that they at the very least, be given an in-home trial.
I agree with much of Tom's post but a few small comments (and as Frantz would say "more to come"):
I prefer a different name than EQ. EQ (to me) is frequency domain based correction (done digitally or otherwise). The TacT, the deceased SigTech, Audyssey, and a few others do impulse based time domain correction. I use "Digital Room Correction"
I totally agree that less is more. If I had an even close to perfect room, I would not use ANY device
I view his position on the Audyssey, specifically the Audyssey SubEQ product, a bit differently. Measuring in 9 positions and using my own target curves, I get the best bass in my room I have ever had. The regular Audyssey product is a GREAT solution for many HT applications. Is it up to the TacT - Not even close! Audyssey Pro is a step up above that but still not in the league of the TacT. But in most HT applications, if I have a choice of Audyssey or nothing, I will take Audyssey. I should add that I have 4 subs and the Audyssey SubEQ product deals with the time/distance issue of sub location as well as virtually eliminating any sub induced room ringing that no other solution has been able to match.
The TacT "compute" function where is shows the "measured" response through the filter is actually a joke. It always tracks perfectly to your desired target curve (if only!!). Even if you measure through a filter (a function the previous models did not have), you will still get results that differ from using other technologies measuring through the same filter like REW, or even my SigTech.
Tom commented about crossover slopes greater than 24db/octave. My TacT 2.2 XP goes no higher than 24db/octave. That said, the ability to transparently integrate a sub to a main is a real strength of the TacT. I have previously tried all kinds of passive and active solutions, all of which sounded poorly.
Steve: Has Amir been to your home with his TacT. I think he does not have the 2.2XP but rather the 2.2 but that should still at least give you a feel for the possibilities.
More to follow!
GREAT post Tom. We need to continue to educate folks - particularly Boomer aged (and older) 2 channel guys who, for the most part, think EQ, DRC or anything like it is spoken of in the Book of Revelation - The Devil Incarnate!!
Hi Steve,
Jack
I did not daisy chain but rather run a separate left and right channel signal to each sub
Any comments as to what I have been told about giving up some midrange and upper range tube magic if I went with TacT
I dunno, Steve. I flipped back and forth between the TacT and an excellent Modwright pre and couldn't be sure I was losing any magic. OTOH, the improvement in soundstage clarity/rock-solid instrumental placement, etc. with TacT was profound. This is in an already well-treated room that I had thought sounded mighty fine except for issues with low bass.
I was hoping you would bring your Tact and some cables for us to play with this week
Steve, if I were driving up I would've come a day earlier so that we could do just that, but...... Hopefully, we can do it another day. Let's conspire Sunday. :)
Ken
[Responding to JackD201]
Microphone EQ:
Actually, even moving the recording microphones can be viewed as a form of equalization, but it is passive and thus will not add electrical/electronic distortion. Moving the mikes at the recording end is the analog to getting the playback set up physically correct at the playback end. Getting the mikes in the correct position should ALWAYS take priority before electronic EQ is even considered.
But, even so, at the recording/amplifying end, electronic EQ is usually a necessary evil. At home, you have "all the time in the world" to get your physical set up just so. Unfortunately, when doing recording set ups, often there is not enough time to find the spot where the mikes are placed to best advantage. Whether you are setting up to amplify a live show or making a recording, the clock is ticking and there is either a fixed show time or the dollar meter is running. In addition, even if you know where the best spot for the mikes should be, getting them there can be either physically very difficult within the time available, or placing the mikes where they would best capture the sound will interfere with sight lines from the audience--a no-no for a sound man.
Many times when I was setting up mikes at church I had maybe 45 minutes tops to physically set up whatever mikes were needed and make sure everything was electrically patched through the mixer to the PA system before it was time for a sound check, and then only a few minutes more before the service started. Nothing was kept on stage so all the mikes, stands, and cables had to be moved into place, set up, and connected in that time. Sometimes, not always, I got advance notice of what musical forces would be involved so I could plan the miking ahead of time.
Thus, I usually had to use electronic EQ. The "foundation" EQ was a Klark Tecknic 1/3-octave graphic equalizer, while the Tascam mixer had three bands of parametric EQ separately adjustable for each of 48 channels available. Sometimes, between live sound reinforcement and recording, all channels were used. That was a lot of set up and knob twirling to accomplish in a very limited time. You either burn out fast, or get good at doing it under pressure. I'd like to think I got pretty good at getting good EQ results quickly.
Old Graphic EQ
I'm not sure when graphic equalizers first started being used by pro-audio folks. The first "audiophile" graphic EQ device I was aware of was a ten-band device marketed by Advent (Henry Kloss) in the 1970s. As I remember, test reports at the time showed that the thing produced on the order of 2 to 3% distortion. I'm not sure why it added so much distortion. Modern analog or digital EQ has vanishingly low measurable added distortion.
Lyngdorf RP-1
Don't let Boz at TacT hear you say that the RP-1 is the "next generation" TacT. He would strongly disagree. There is quite a bit of "competition" between the two companies, to put it politely.
Measuring from multiple spots has its plusses and minuses, I think. The idea of measuring from multiple spots is to both broaden the sweet spot and to avoid applying EQ to frequencies where the response changes a lot over a small distance. Both techniques have their advocates. Certainly if you are setting up a home theater where you expect to usually accommodate two or more listeners, you should measure in multiple spots.
My reference audio room is a one-seater. Those in favor of measuring from a single spot, and I fall more into that camp currently, will say that as long as you sit still, you want the spot to be as sweet as possible. I could care less about what is going on elsewhere in the room since I actually LIKE to listen with my head rock steady.
You can just run multiple measurements from a single spot if you want to, regardless of what the instructions say. With the TacT, I've found small but subjectively noticeable improvements from running as many as 70 measurement pulses with the mike in the same spot, as compared with, say, five or ten pulses.
My unit has the crossover specified in terms of "order" not dB/octave. It is specified as able to apply crossovers from 1st order to 24th order. I never use anything steeper than 18th order. First order is 6 dB/octave and every order number increases by another 6 dB/octave. Thus, a 4th-order crossover is 24 dB/octave. A 24th-order crossover is 24 x 6 = 144 dB/octave. You can verify that the crossovers are really this steep by looking at the measurement graphs with the crossover active (rather than inactive, as you would usually measure), or with independent measuring software.
Checking the TacT Web site today, it appears that the specs for the RCS 2.2XP may have changed. The site now talks about having a maximum crossover slope of 60 dB per octave. That would be 10th order. Either that, or this language is left over from the old RCS 2.2x days. That version had a maximum crossover slope of 10th order, which would be 60 dB/octave.
Maui modded???
Maui Mods is a company run by Anthony Padilla. Anthony also, I think, works as an employee or contractor for TacT. He sells after-market parts for TacT equipment. I have never seen an unfavorable comment about the sonic quality of any Maui Mod for TacT; response seems to be universally enthusiastic. Check the TacT forum on Yahoo for customer service comments.
That is odd. BTW, 2.2XP won't do (or at least mine won't do) 1st order - only 2nd thru 24th.
Tom, have you tried digital input in order to avoid the redundant D/A, or is your front end strictly analog? When I eliminated unnecessary D/A, I heard a significant improvment in transparency
Sorry, you are correct about the minimum crossover order being second order, which is 12 dB/octave. I just checked the TacT help screens dealing with the crossover settings in the V1.0 version of the TacT software. The maximum crossover order available is, as I said 24th order.
Yes, I've used digital inputs into the TacT. I've also used the digital outputs. Obviously, if a section of a unit has any audible distortion, bypassing that section will lessen any audible distortion you hear from the unit as a whole.
Right now, I'm only using the A/D converter section of the TacT. It converts the analog output of my Oppo BDP-83SE (playing SACDs and HDCDs) to 24/96 digital words and I run the digital output of the TacT into my PS Audio Perfect Wave DAC for D/A conversion and balanced analog output to my Bryston 7B-SST amps and JL f112 subs.
