It’s all about the bass….
Some fine details are worth noting. First, I turn the ELF control (effects frequencies under 15 Hz) to its minimal setting. I really don’t care much about information below 15Hz and a minimal setting here actually sounds cleaner than any other setting. (i.e., it’s a familiar “less is more” phenomenon). Second, I do not use the DSP program at all. In the past, I found it useful if one is crossing over at a point that is in the 60-80 Hz range, as JL recommends. However, in my case, I am crossing over at the lowest point possible which I estimate is 22-25 Hz (the lowest frequency crossover point is not clearly marked on the controls). Keep in mind that just because the crossover is set to 25Hz does not mean that is the only frequency (and below) where the sub is operative. Rather, the crossover point is a -24dB point, so in fact it does have significant output that reaches well into the 30+Hz range. Therefore, it is a mistake to say the sub only works at 22-25Hz and below. This is not true at all, even though that is indeed the crossover point. (Amazing to me how many people don’t understand this). This of course is what makes blending the output with a full range speaker so challenging. It is also why the most important controls to adjust for blending the subs and mains are obviously the volume and the phase control. It is the setting of the phase control that is the key to making the sub integration as seamless as possible.
RIGHT SUB SETTINGS FOR JL GOTHAM V2
