Exactly my experience here. Well done.On faith I went for the Omega AES/EBU's and glad I did. There are so many ways it benefits the system I could spend a day or more. Net: every thing just sounds more real, with greater detail, separation/pinpoint of sources, yada yada yada.
Omega is very special. The Omega USB was also shockingly superior to the Sigma USB.FWIW, my Omega AES/EBU is shockingly superior to the Sigma v2, I did not expect that.
I purchased a Omega USB because all the hype , I really didn’t think it was going be as good as it was ,Omega is very special. The Omega USB was also shockingly superior to the Sigma USB.
i have Everest + sigma XC. Was omega a significant upgrade? Curious about this!Let me tell you about my experience. I first had a Denali 6000v2 with a Sigma XC. Then I went to an Everest + Sigma XC and finally to an Everest + Omega XC. All the changes were positive, but not equally positive. If you have to choose between Denali 6000V2 + Omega XC and Everest + Sigma XC, my experience is that you choose the latter, hands down. Make numbers and talk to your dealer to get the 6000V2 for you.
Amen. One of the most influential cable updates I have experienced!I purchased a Omega USB because all the hype , I really didn’t think it was going be as good as it was ,
best cable I bought to date getting a 2nd for other system
The change of cable is really appreciated, now well not as much, as changing the Denali for Everest. As the price difference is important I would try first.i have Everest + sigma XC. Was omega a significant upgrade? Curious about this!
@nonesup Are you saying going from Sigma XC to Omega XC was not that significant of an upgrade all other things considered?The change of cable is really appreciated, now well not as much, as changing the Denali for Everest. As the price difference is important I would try first.
I don't actually have the Everest yet, trying to figure out if I go Shunyata, where to put money first.I say that in my opinion the change from Denali 6000 S2 to Everest was more significant than the one from Sigma XC to Omega XC. But now rereading the post I see that you already have Everest, in that case I do recommend buying Omega XC.
I'd do Everest and XC firstI don't actually have the Everest yet, trying to figure out if I go Shunyata, where to put money first.
Not surprised based on trying some Omega clock cables for the master clock to the Rossini. Really big upgrade over the Apogee Wydeeye 75 ohm cables.How you liking your Omega AES/EBU cables? I upgraded the dCS Vivaldi Upsampler to DAC from Sigma v2's and these are surprisingly much better. I like the black look by the way, especially considering dCS's habit of using black background for their displays.
I'm still searching for an appropriate sized mountain climber to place atop my Everest...
I should mention that the Omega 75 ohm cables are still breaking in. Using a 407 track playlist on auto to do the break-in. I hear that Day 3-4 is where the magic really begins. We are on Day 2.
I can’t find a fan with BNC connectors.In the past Shunyata suggested using a fan.
I can’t find a fan with BNC connectors.![]()
