Adding Quicksilver Mono 120 to the listReally want 100 wpc. Thinking KT88 based. I dont have $30K so forget the crazy expensive brands.
Ref75 SE does a nice job of driving my Wilson Sasha ll’sNot quite 100W however perhaps consider an ARC REF75 running KT150’s
All volume manufacturers have a percentage of faults, for every negative anecdote you will find several others stating no problems in years of ownership.@Daverich4 I was considering ARC but they are known to have reliability problems and run their tubes hard. I will reconsider.
I demoed a Carver 305 and it was good but not great. I wonder if their other offerings are better.
Have you considered the Prima Luna Evo 400. The mono's come with EL34 tubes, but you can put KT88. Considering they output 82W in triode with EL34, I would think you could reach 100W even in triode with KT88 tubes. I don't know what you budget is, but they are under 10K for the mono pairReally want 100 wpc. Thinking KT88 based. I dont have $30K so forget the crazy expensive brands.
Might want to look at Clayton Audio.I always pictured Mc as mid-fi. Though the 275 is given a class A rating in Stereophile(?)
BTW, I am open to other manufacturers my budget is 5k and I can go used.
I remember reading lots on Audiogon about them...fascinating. Monstrously powerful! I bet they are fantastic...do they also design preamps? Are you using a full Clayton set of pre/power?Might want to look at Clayton Audio.
Boutique builder of no ill repute. All class A solid state. Beautiful sound from these devices, truly
they come up on A-gon from time to time
I have had the S100 stereo amp and currently run a set of custom made/specified M200 monos…. Utterly fantastic amps
I don’t actually think he does a pre amp, or used too but not nowI remember reading lots on Audiogon about them...fascinating. Monstrously powerful! I bet they are fantastic...do they also design preamps? Are you using a full Clayton set of pre/power?
