While I have limited exposure to dacs I can unequivocally recommend the Lampizator Amber 3. it will hold its' own in a hi res system. There are a lot of good dacs from a technical perspective. The question is can the convey the soul of music. That is question for you.
As i heard the above proposal several times in my system I strongly believe A3 ticks all the boxes you mentioned...I am thinking in terms of warmth, sound staging, detail, and realistic tone.
Are there any that would satisfy the analog LP lover?
I am not sure what "boxes" mean. Your results are certainly at odds with mine. It may well be our results are system dependent. I think it is worth a try.As i heard the above proposal several times in my system I strongly believe A3 ticks all the boxes you mentioned...
“warmth, sound staging, detail, and realistic tone” - those “boxes”I am not sure what "boxes" mean. Your results are certainly at odds with mine. It may well be our results are system dependent. I think it is worth a try.
If I may mix metaphors the Amber checked all those boxes in spades. YMMV.“warmth, sound staging, detail, and realistic tone” - those “boxes”
I was not thinking of a $500 turntable.I am thinking in terms of warmth, sound staging, detail, and realistic tone.
Impossible.I was not thinking of a $500 turntable.
More like a perfectly set up $8000 turntable with a $3000 mc cartridge.
I have one of these and like it very much. A bargain for the price.The Audio Mirror Tubadour III SE is supposedly rather good.
That is what I thought!Impossible.
Maybe check out the Luxman DA-250.
Always wanted AMPS, CD and DACS that gave the most detailed sound, was a huge fan of micro detail. Always had the feeling i was missing out on something. Friend had bought a Luxman Amp, missed the micro datils but so very much enjoyed the rich and fluid way of how it sounded. So had a demo with the Luxman DA-250 DAC, also for having a good headphone amp, and ordered one the very same day.
Sound is warmer/richer then most dacs, almost like a valve sound, plenty of details and the highs are just awseome sounding.
Yes, all personal taste and system depending on the match but for me it was a fantastic upgrade.
