Hello Sniper17,
Congratulations!
IMHO your Nagra Classic Tube DAC deserves a transport better than the Nuprime!
+1
Here is a nice CD transport comparison:
https://www.hifi-advice.com/blog/re...iews/jays-audio-cdt-2mk2-and-dac-2-sig-part3/
Matt
Hello Sniper17,
Congratulations!
Thanks, yeah, let me know if you don’t mind. Earlier versions seem to have v-shaped attachment point to the chassis, where new ones now have the + mark...Mine is pretty rock solid. I haven’t noticed any play. I use the remote most of the time but I’ll check again. Do you have the power supply and do you know if you can power non Nagra gear.
I have called my dealer and they are waiting for Nagra to reply... it’s been a couple of weeks...Surge1, yours does look different. Wondering if something jiggled loose in shipping? Have you called your dealer?
Redphu, I have a Nagra Classis PSU. I use one outlet to power a classic phono and the other to power my Grand Prix Audio turntable power supply. So yes, you can as long as the input source is the right voltage and current limits.
Thanks! Yeah, so they changed how the volume dial is secured. No idea why. The new style has play; but it can be fixed with a shim... let’s hope Nagra fixes it. Again, not a huge deal and on a lesser priced DAC I wouldn’t mind. But on a DAC that retails for nearly $30K, it needs to be fixed!Here’s mine
Nagra and/or your dealer will fix it. They are a way beyond first class manufacturer. I am sure they are also digging into their engineering and build teams to find out what happened. Let us know how it turns out.Thanks! Yeah, so they changed how the volume dial is secured. No idea why. The new style has play; but it can be fixed with a shim... let’s hope Nagra fixes it. Again, not a huge deal and on a lesser priced DAC I wouldn’t mind. But on a DAC that retails for nearly $30K, it needs to be fixed!
