When you use the preamp, do you bypass the MSB volume ?There are pros and cons in omitting the preamp for MSB Select/Ref DACs, even if pairing them with MSB's own poweramps.
I did test the MSB poweramp with and without preamp :
1. Select DAC direct
2. Reference DAC via a Nagra HD Preamp
Although the comparison was not in the same syatem nor with the same dac, I got a glimpse of the effect of both of the ways.
I personally prefer using a preamp : the sound got better dynamics/authority/stability.
If without preamp, there was more transparency.
Therefore I use my Select DAC with a Bespoke Ultimate Silver passive preamp and a pair of Totaldac D1-Driver xlr version.
Thank you very much for your reply, your thoughts and experience is very helpful!A Select DAC owner friend and I tested the effect of different Select DAC volume levels when using a preamp with it.
We found that vol level of 100 didn't give the best sound.
Levels of 9x were better.
My personal preference is 93.
YMMV.![]()
Yes, that's what I am doing.May I ask if you adjust the volume level via your preamp mostly ,and the MSB volume remain at 93 ?
I know ah, but ...Curiously, the early version of the Select manual (2015) stated that 94 would be the optimal level when using external preamp...
Its quite an achievement to get it to sound anything like good in those show environments, with feeble, noisy mains, poor earths, EMI soup, high ambient noise, lots of seismic vibration, ever changing room acoustics and speaker positioning designed to sound good for a larger audience. Challenging, to the point its not really possible to overcome all the problems effectively. Compare in your mind that environment to a fully optimized listening room and you can imagine the scale of the improvements / deficits. Magicos in an optimised environment will sound truly stunning, but its not the MSBs that are at fault. Hotel rooms during show time are positively torture chambers for highly resolving equipment, testing their abilities to sound good under extremely adverse conditions.Last year in Munich Show, MSB used Select direct to M500 driving a pair of Magico M6.
I sat down and listened for some time, 15 minutes or so which was quite a lot of time given there were some many rooms to go to. My impression at the time was very detailed sound but rather plain and gentle. Dynamic could certainly be better. I use a pair of Magico M6 in my home, so I have a good idea of what M6 can do.
A good preamp will certainly enhance the dynamic.
Vince Galbo, National Sales Manager for MSB has been a huge believer in clean power for many years. He swears that running a separate twisted 6 gauge ROMEX (if the run from the main panel is over 50ft, 8 gauge if less) to a dedicated four outlet panel will be one of the biggest improvements you can make in a system. For me, the only way I can do that realistically is to run a conduit on the side of the house up to the attic and then down into my dedicated music room. Not exactly winning over the wife with that idea, though!I have a short (3’) run of 10 ga romex running to an outlet connected to the subpanel that feeds my room. I plug the typhon into that outlet. It reduces the line noise going into all the 5 outlets by 50%.
Did you ever get a chance to try this combination? I’ve enjoyed (bigger) Bryston amps more than their reputation on this forum would suggest is likely.Just ordered a Bryston 14B SST3 stereo amplifier for my theater, but I think I'll also try it for the M6 speakers to compare its sonic signature to the MSB S500. I know that might not be a typical pairing price-wise, but all I care about is how something sounds ... I'll report back (assuming I can move it upstairs by myself) but this will take a while (needs to be delivered, burn in, etc).
Most intrigued as well...particularly given that he uses MSB500 with the Magico M6 and is using the Bryston 14BST3 with a superb Magico M Project...would be interesting to hear how the 2 amps compare.Did you ever get a chance to try this combination? I’ve enjoyed (bigger) Bryston amps more than their reputation on this forum would suggest is likely.
