When you say FS brand transceiver do you mean Finisar?SM Fiber is the standard for Multimedia communications
MM Fiber was developed only to lower cost facilitate terminations and for short distances.
SM Glass Fiber is about 10 Micron, MM is about 100 microns so if you compare the area we are talking 78.54 ?m² vs 7,854 ?m²
SM cables can transmit data faster, longer distances because they generate much less distortion than MM fibers, since in MM the signal is constantly bouncing.
In any lab test in a control environment regardless of cable length, and using perfectly terminated high quality fiber cables, a SM cable will outperform an equivalent MM cable in every single aspect, specially data integrity, bit errors, timing errors and distortion. So if someone feels a MM sound better than the SM, it might be the MM Cable is better terminated or the quality of the equipment/transceiver used with the MM was better, there can be hundreds of variables LOL.
I Spent my work days designing large and complex Fiber networks LOL!
BTW Few Tips
Limit Media Conversions - The thing that affect the most a network signal integrity is conversion going back and forward between, fiber --> copper --> fiber --> copper LOL will degrade the signal more than adding 100 meters of Cat7A cable LOL.
Use high Quality Transceiver - If you are going to convert use a good transceiver, remember the transceiver is what actually convert the light to pulses and vice-versa is not your switch or EtheRegen! Don't use FS brand a good HP or Cisco will outperform them and are much more reliable.
And Lastly, Those Bulky nice looking Field install IP20 cat 7A or Cat 8 plugs that high end cable use are some of the worst performer connectors available! We did a large test at our ISP and we used a top of the line Anritsu NA and the best performance on Cat 7a and 8 cable termination was achieved using the Platinum tools ezEX48 crimp plug LOL! Believe it or Not LOL! we tested it like 10 times LOL.
The reason is very simple and obvious, the weakest links in any cable are connectors and signal medium.
Signal flow in a Crimp plug: spring bars --> Plug pins (gold bars on the plug) --> Wire That's it the cable is directly crimped to the pin that connects to the jack spring bars
Signal flow in a IP20 Field plug: spring bars --> Plug pins (gold bars on the plug) --> Solder connection to PCB traces --> PCB Traces --> Solder connection to IDC Crimp Connector --> wire! LOL
Once we saw this we immediately understood why a high quality crimp plug outperformed the Field install ones.
There is always that misconception that because something is bulkier, more expensive is better for everything! IP 20 Field plugs are designed to meet 2 requirements, IP20 environment certification and to be easy to install with no tools. They are not designed to have better signal performance.
Just like some Aerospace Cat7 cable we tested From Gore Technologies, very expensive cable ($27 a feet bulk) Silver plated wires all Teflon insulated with Teflon tape around even the shield was silver plated, But it end up at the bottom in performance, because is not designed for that!
First the conductors are stranded not solid (bad for performance but great for reliability and flexibility) and the silver plated wires and Teflon insulation was not designed for performance but for High temperature resistance in space.
To the folks using Finisar transceivers, did you notice any break in with them?
BTW Few Tips
Thanks. Good to know. They sound pretty edgy now.Mine needed 2 weeks
Never.To the folks using Finisar transceivers, did you notice any break in with them?
