2.1mmMay I know what is the type of DC input for Melco S100, is it 5.5X2.1mm or 2.5mm?
Dela/Melco of Japan announces an optinal optical conversion set for their S-100 audiophile switch.
It comprises an optical media converter, an optical fiber made by Corning and optical transievers :
Interestingly Dela/Melco has chosen multi-mode but not single-mode optical connection.
Here is the webpage :
https://www.dela-audio.com/product/op-s100/
Oh no I need help as I just received the Melco S-100, I just ordered the Jcat M-12 Gold Switch.
I use the same 100Mb port and my Roon habitually loses its connection and cant find my Extreme. I put it down to my shitty network but your comment makes me wonder whether the Melco port choice is to blame....Been using the S100 for the past few days. Streaming via Roon. The 100Mb port seems to "time out" after some hours and I lose connection to my endpoint. The 1000Mb port seems stable. Anybody else seen this? Wondering whether there's an issue with my network, or whether Roon over the 100Mb links is a bad idea? Given the 100Mb ports of "optimised" for sound quality I'd like to use them (haven't A/B the ports yet to hear if this is even an issue).
I use a 100MB port without any issues connected to a NUC7i7 endpoint. The issue is most likely not the Melco but some other aspect of your network configuration. Maybe your endpoint doesn't like the 100MB stream. Are there endpoint NIC settings you can change?
Which SFP port are you using? 8 or 9? I'm currently using 8 but I notice it is tied to ethernet port 8 by some priority logic and am wondering whether port 9 might be the port to use. Just trying to remove variables...
It's the top one. Not sure which number. Also, I have used 3 different transceivers (Planet Tech and Finisar) and all worked fine.
