The Falcon only puts out 5 Watt 115 VGood. But we should not forget that step up transformers at low power usually are not very efficient.
Do you have a value for power and voltage?
I don't think 5 watt will be enough.The Falcon only puts out 5 Watt 115 V
Thank you Franscisco, please check the frequency too !I will measure the power consumption of the A80 capstan motor later and will report.
I imagine it is even more than 25 W on startup, the Ps Audio can do it no problem. I have one 300W model and 2 500W models, but the adjustment is not as fine as on the Phoenix supply,I don't think 5 watt will be enough.
david
25w is probably enough.I imagine it is even more than 25 W on startup, the Ps Audio can do it no problem. I have on 300W model and 2 500W models, but the adjustment is not as fine as on the Phoenix supply,
Check the frequency too !
david
Very good guess! David, some time ago you posted a picture of the AS 2000 /AF0 motor , praising its characteristics. Do you remember at which WBF sub-forum?
Yes we could all need som audio pornNo, what would you like to know I can post again? Is it just the picture that you need?
david
david
The PS Audio can be set anywhere from 50 hz - 60 hz.Aproximately 24 W. The frequency is 50 Hz, the Studers operate the capstan in a servo system at mains frequency controlling the amplitude. For 60 Hz operation we must change the capacitor, if you want to operate at other frequencies you must tune the capacitor.
That does look very powerfulHere it is next a typical tt motor. Studer motors are about the same size as the small motor in the pics.
The one on the right is about what you used to get in a typical high end tt, of course these days it's mostly dc motors.That does look very powerfulIs that one the right made to run a matchbox racecar ?
And some manufacturers use several not so powerful motors, but i have a feeling it’s mostly marketing, the more motors the more expensive. Seems especially the Germans go for thatThe one on the right is about what you used to get in a typical high end tt, of course these days it's mostly dc motors.
David
The Condor PSU will not drive your
The Condor/Eclipse package should be more than capable of driving your platter. If you want to use the Studer motor, look at the SG4 DIY kit:
https://www.diyaudio.com/forums/analogue-source/298018-diy-4-phase-sinewave-generator-turntable-motor-drive.html
I believe DIY member ralphfcooke has done a 3 phase version to drive a Papst motor using step ups and conventional class D amps.
