Pelo,
I would strongly suggest that you install two dedicated 20A outlets with at least hubble hospital grade outlets for your amplifiers. You have monoblocks but they are being dynamically constricted by not having each on its own outlet. This would be a basic infrastructure upgrade and no matter which amps you buy or use in the future would benefit from this. This is something that is not typically hugely expensive (maybe $1000 or less) unless there is some extenuating circumstance with how your house is constructed.
I would start with this before I changed amplifiers.
All the best,
Todd
All the best,
Todd
