The latest generation of M/L speakers have the same basic sonic signature that the +20 year old stuff has. I mean this in a good way, the openness, the clarity, the speed and so forth. Do they Rock? Yes and no, I listen to Progressive Rock and they do that very well. I think they do a pretty good job on classic rock too, but think of all the "Myths", this one has a tiny bit of truth to it.Busting Martin Logan Myths
Somehow I did not know the membrane was glued to the stator, nor did I know it was in tension. Never really thought about it I guess.Stretching the ml panel
Basic room treatment for ml
I still don't know how they keep the membrane form collapsing onto the stator![]()
A couple of things....first the dispersion comments. Yes the curved panels probably have widened the sweet spot but I find the bigger problem is vertical beaming. If you are seated things are great but you stand up and it's like you've put a pillow case over your head. Regarding the life expectancy of their panels, I replaced the panels on my Aerius i's when they were 12 years old. When I spoke with someone at the factory to order the panels, he said that 12 years is about what you could expect to get out of them. Lastly, I have my Aerius i's now in my HT, LF and RF along with the ML Cinema center and I wouldn't change a thing.
What I thought was most interesting (and I have a hard time believing it) is that most Martin Logan owners use receivers. Really?? Is that a marketing ploy that helps or hurts them? Is ML trying to cater to the receiver crowd?
And by the way, I bought a pair of the original Aerius brand new many years ago and I had to change out both panels and one of the woofers.
I just found the same video doing a search, and was about to post it but see it is already posted.Basic room treatment for ml
For Martin-Logan electrostatic speakers I advocate leaving the front wall moderately reflective (or at least no absorption or diffusion to start with) at least until all other acoustic issues have been solved first.
After all other acoustic issues have been solved, then it is a matter of personal preference whether to absorb the rear wave, to diffuse the rear wave or to manage and utilize the rear wave for sonic spaciousness (as I practice).
. . . Personally I consider . . . 6-8' ideal.
