Just another Frivolous Youtube video made on my IPhone
Change to the crossover...
I won't make any changes yet for a couple of reasons. One is the sound is pretty fantastic overall -- best I've had. Another is that the tubes are breaking in and starting to sounds less "bleached". Finally, I think this could be a function of the silk tweeter in the Midas. The larger Odeons use a Mylar tweeter. I wonder if it's the tweeter that is making vocals sound slightly 'papery' around the edges.That's the opposite of what I want. You should try the takatsuki though with 8 valves too expensive. The EML might be a cheaper option. Definitely don't go for KR or Elrog as they are cleaner sounding and less forward.
Sophia has less control but is airy in the mids which people like for vocals.
I gravitated to Sophias in the past for what they did on vocals but I agree about the lack of control -- especially in the bass.That's the opposite of what I want. You should try the takatsuki though with 8 valves too expensive. The EML might be a cheaper option. Definitely don't go for KR or Elrog as they are cleaner sounding and less forward.
I was reading about the KR 842VHD which, if I understand correctly, is a drop-in replacement for their 300BXL. Have you heard it? From the descriptions I've read, it's even 'cleaner' than the KR 300BXL.That's the opposite of what I want. You should try the takatsuki though with 8 valves too expensive. The EML might be a cheaper option. Definitely don't go for KR or Elrog as they are cleaner sounding and less forward.
The Midas really is quite good and a very good value. I didn't want to say anything about what it sounds like in comparison to the No. 28 because I heard them in different systems and different rooms but my impression is the same as yours.The Midas is an overall more lightweight sounding speaker than you will be getting. I heard them at my customers and compared to his big Odeons it was not the same galaxy. However, the Midas is an inexpensive speaker and for that money it is quite good indeed and easy to drive with nice amps, which further helps it's sound.
I'm getting the No. 33 but I've only heard the 28 and now the Midas.Are you getting 28s or 33s?
Ah ok, and when will you get the 33s?I'm getting the No. 33 but I've only heard the 28 and now the Midas.
I gave my dealer the down payment on Thursday and we hope to find out Monday if Odeon has a 33 on hand (perhaps a show model). If not, or if I don't like the colour scheme, I will have to order one built. (I'm not sure what colour scheme would be best for my place) At that point I will get an estimate on the delivery.Ah ok, and when will you get the 33s?
Read that A typical human expends approximately 2000 kcalories per day = 8368 kjoules ? 83 kcalories/hour ? 96.8 Watts (joules/sec). The human brain typically accounts for 20% of that energy, so a human brain runs on about 19 watts. That's the same as a 300b valve
Marc, what valve are you? 46? 50?
I am Eimac 405 TL
Those look a lot like the Odeon Rigolettos I used to have...really beautiful.
I'm open for suggestions for the colour of the body and the colour of the horns of 33s.Those look a lot like the Odeon Rigolettos I used to have...really beautiful.
