since the bits of data (analogous to a master file or tape) gets converted to dac readable data (vinyl mastering process) by the server, i view the server + data = pressing.
further.....since everyone's data is basically identical; the further analogy is that the server makes a difference like the pressing makes a difference.
two systems with exactly the same data and dac, will sound different with different servers, like two systems playing the same recording, with the same gear, but different pressings.
essentially we have moved on from data being significant. it's not changed in 20 years. dacs are now better. but the big change is servers have matured. they had a very long way to go from the dirty things they were.
Mike, I find your analogy that: Extreme = best tt PLUS best pressing, and in effect because Tidal is providing the best digital files for all servers that utilise it, Extreme is equivalent to the best tt w the best vinyl collection.
I think my early audio experience is telling. Back in the 80s and 90s I regularly went to demos at Grahams in N.London, the premier UK dealership for Linn and Naim who had the stranglehold on British audio.
There was the religious run thru the range of Linn tts, from sub £500 Basik to £3k LP12 Sondek (remember these are prices from 25+ years ago). And of course, arms and carts.
And it was ably demonstrated that the strong message from the dealer to go priciest LP12 Sondek tt, and more affordable arm and cart, made sense within a restricted budget, and go to TOTL arm and cart at later date when funds permitted.
I wouldnt be at all suprised that if Linn were promoting servers today, an Extreme in their line would be advertised as THE key component in the source, and the message would be hold back on the dac if you have to. And I suspect the USB cbl would be considered part of the server.
So Extreme plus best USB > best dac.
The Q then is, just how good are dacs in the $5-10k bracket.
