Congratulations.Fedex complied!
Hi Ricardo 007AC cleaning with Entreq.
In the 2014 Audiobeat article of Roy Gregory there is mention of using a silver tellus connected to the grounding post of a Nordost qb8 powerstrip.
Since then Entreq introduced the cleanus and silver cleanus, which can be optionally connected to a grounding box like tellus or silver tellus with a SS eartha cable for further results.
Does anybody can report on these 3 various ways to treat AC current?
Same here. I have an Audio Sensibility distribution box's grouding post connected to Silver Tellus via an Ocellia grounding cable. The Silver Tellus is only carrying 2 Everest knobs now. No booster box either. An Atlantis Tellus won't work here because it will block the infrared remote control signal to my DAC. Will likely get an Atlantis Minimus and the remaining 2 Everest down the road if opportunity arises. The distribution box is connected to a Furutech stack on the wall via an Ocellia power cable. The power amps bypass the distribution box and go directly to the Furutech stack via a twin headed Ocellia power cable. Both plugs connecting to the Furutech stack are clamped together and supported by a Furutech NCF booster. For filtering, there is an Audio Prism LF-1 Mk III parallel filter on one of the sockets in the distribution box. There is an Ocellia filter in series with the DAC and nothing else. A Blue Circle Yellow Banana surge suppressor is plugged into the distribution box when the system is not in use. Nothing other than incandescent light is allowed on the same power circuit as the system. TV and Bluray player have their own surge suppressoing powerbar but the whole thing is on a separate power circuit, with the Bluray box sending audio to the main system via a glass Toslink cable. I don't listen to TV through the main system that all much but I do have a cheap driver and power tubes for such occasion just in case.Hi Ricardo 007
All I can tell is the way I treat my AC ground. [...]
I live out in the country, all newer underground wire, my own dedicated transformer for our house, etc,, so I thought trying an ENTREQ couldn't help much. I bought a used Olympus Minimus and plugged it to the outside barrel of my Audio Research Anniversary 40 and wow, just wow! Good, bad, thick, thin, huge soundstage for a full 48 hours. That gave me time to read about these things. I am absolutely shocked at the level of improvement at this point. I'll be buying another for my phono stage.
How do you get these Nordost grounding cables? Nordost does not sell/ produce it themselves?Hi Dan, Tony is my friend.
He is using Olympus Tellus now. At least 5 people have 1 Odin as ground cable, mix with V1 & V2 in Vancouver. At one point, Tony used 4 Odin ground cables. Now back to only 1 Odin.
Edmund
Thanks for the reply. Maybe the original poster or anyone with this kind of experience can comment on the sound quality of these diy methods vs purposely built grounding cables from Entreq. Given that Nordost and especially Odin cables (2000usd) are expensive, versus grounding cables from Entreq (under 1000usd). Is it worthwile?They were taking odin power cords and modifying them with spades and other connectors, I believe.
By the way, 2 Eartha Apollo Infinity cables have been available. One has RCA termination and the other with USB. If someone is interested in buying them at 50% of the fare price, PM to me.I have sent many emails to Entreq for information and have NEVER received a reply. I live in the USA.
ozzy
