It's called the ML 2.1 (now the 2.2) which I owned and indeed an 18 wpc SET. It was the second best amp I have ever owned
Steve, was that a DHT?
I come back to my main question - do you have traceable evidence that positive identification using ABX took part in the audio hardware developments of the last 30 years ?
BTW, I will deliberately ignore comments that are not relevant to my main point I am addressing. At no point I was interested "infinite sensitivity of human sensations" in this post.
It's a pretty fine line, micro...
BT - blind test
ABX - blind test with a control -- "is X A or B"
DBT - double blind test - even the person conducting the test doesn't know which choice you're listening to.
Where there is a significant difference is in use. ABX is most commonly used, obviously, to determine if there is a perceptible difference at all (audible in our case). Thus the X. And while that is probably not as common in audio product development as testing for preference (BT and DBT), it wouldn't surprise me at all to hear it is being used by science-oriented companies like Harmon, who understand the power of human psychology, and know that if they are testing for preferece between subtle differences, people are likely to perceive a preference, and state one, even when they can't actually hear a difference.
Boy could that booger some test results.
Tim
I still do not know why there is such a focus with ABX in audio, and not go further with validation by repeating the tests using same-different methodology.
Same-different relies upon solely AB, without the mechanism of forcing both to be compared to X as in ABX.
Hey, maybe there is a new market for you Tom? The Danley Sounds intelligibility test disc?
Anyway, no-one else commented, but it just JUMPED out at me for some reason!
Tim, more commonly used across the various disciplines is actually same-different test methodology, and not ABX, which seems more tied in with audio for some reason and the same-different methodology is not used.
This is an interesting point, because the key research by Floyd/Sean/ and others done at both NRC and Harmen in the development of speakers did not use ABX from what I can see and have read fom the papers published;
Cheers
I ran across this on PFO.
Hardly a definitive study, but she gets my vote.
http://www.positive-feedback.com/Issue56/abx.htm
1) All amplifiers sound the same.
2) All CD players sound the same.
3) A coat hanger sounds the same as an expensive interconnect.
4) MP3 sounds the same as CD.
5) CD sounds the same as SACD.
6) High resolution PCM sounds the same as DSD
Thanks for pointing out the site, the samples would be very useful for testing "transparency" of systems. Unfortunately, what is described there is good for distinguishing variations in audio with fixed gear, and I was talking about distinguishing variations in gear with fixed audio. The latter is what most people are worried about, which in turn brings in all the problems I was alluding to ...My last ABX test was administed yesterday by me to me, and related to the files that you can download from this web page:
http://home.comcast.net/~arnyk/pcabx/jitter_power/index.htm
The piano is well known for being very diagnositic for power line jitter.
The jitter in the -20 dB sample is huge, compared to real world jitter. Can you hear it?
It aso shows Harmon has gone well beyond ABX.
That is a false conclusion. Reasearchers at NRC were doing ABX tests for a number of different chores including developing speakers, at about the same time we were developing ABX for our own use. The Vanderkooy/Lipschitz papers about polarity were written as a consequence of work that we did together. My recollection is that I read about "A/B/X" tests that V&L were running and called Stan up, introduced myself, and told him about what we were doing. Since Waterloo is fairly close to Detroit, Stan and John volunteered to drive over and meet with us at one of our regularly scheduled club meetings. They had a simple A/B/X comparator that was a little less elaborate than ours, but still perfectly usable. The results of that meeting ended up providing the data for the V&L AES paper about the audiblity of polarity. Excluding polarity as a strong sound quality determining factor in the design of speakers headed off a number of trips down rabbit holes.
...and never gone back to the useless foolishness of sighted listening tests that most Audiophiles still stand by as the only legitimate arbiter of sonic quality.
Tim
In fact same-different testing was the immediate predecessor of ABX. We did a number of same/different tests, found that it was too frustrating and therefore insensitive, and left it behind. On balance, an ABX trial is a composite of a bunch of same/different tests.
That's another thread Tim: Are sighted listening testis usless and foolish? Maybe you should statrt it.
That's pretty inconsistent with what you have said elsewhere.Audiophiles often behave as if every amplifier sounds different. The buy amplifiers like many people buy socks. The science says that some do sound the same, and some don't.
What is a "well-made" MP3?A well-made MP3 can be indistinguishable CD, or not.
Frank
Then more recently we have the study of room correction products, amongst other studies that could be mentioned.
It is fair to say all of these scientific studies influenced product development, but none used ABX, however I appreciate there maybe scientific research papers by them that are ABX, might be worth listing some that you feel were used in product development as it would help.
That's pretty inconsistent with what you have said elsewhere.arnyk said:Audiophiles often behave as if every amplifier sounds different. The buy amplifiers like many people buy socks. The science says that some do sound the same, and some don't.
amir said:What is a "well-made" MP3?
