Be careful Terryj; don't embarass yourself. Frank could id a change of fuse blind from the next house. You might not even need to drive to Sidney.
Tim
Tim
Amir was the one who knew exactly where the ball was: scientists and "objectivists" may love the concept of a "pure" experiment, but the majority of the rest of us will just think, "Buggah this for a joke!" ...In blind tests, it is very easy to give up and just vote randomly. The process is tedious and boring. After five minutes of you, I suspect many voters just want to get through it if the differences are hard to spot and vote randomly.
Where these two points of view can resolve their differences
and meaningly merge to an agreement is for firstly the "rational music lover" to accept that something more than "straightforward" application is required, it will still all be totally "correct" principles, but doing it in a relatively unsophisticated and dumbed down manner will not achieve the result the other party knows is possible.
On the other hand, the "audiophool" has to jettison the belief in "magic", there ain't no such animal, not in audio at least! By luck and endless fiddling he has managed to achieve superior qualities in his sound compared to what the other party is content with, but he needs to understand that there are still very real, very rational principles at work making it happen for him. He may not understand the principles, almost no-one may appreciate what they are, but you can be certain the underlying mechanisms are perfectly capable of being fully, "scientifically", understood if someone makes a major effort in tracking down what's going on ...
I think that's an incorrect view of the rational music lover position. I think the position was best summed up by the ghost of Mrs. Landingham in the season finale to the second season of the West Wing: "show me numbers."
What could I conclude from that? I could conclude that after enjoying 3 weeks of expectation bias, as soon as I was unable to know I was listening to the beautiful black headphone amp with glowing amber tubes, that I had dutifully warmed up prior to listening, my listening experience changed dramatically. I could conclude that I am not immune to bias and that on that day, in that system, listening blind, I could not reliably differentiate between those two components. (...)
What I concluded from that headphone amp experience, and a couple of similar experiences with other amps, and DACs, has changed my approach to the hobby, and greatly enhanced my ability to enjoy the music. Who needs statistics?
Tim
Curious situation. Forgetting about how you expect to be able to reliably differentiate anything without proper statistics and methods, can you tell us why you decided to carry the blind test? What triggered this desire? I ask it because it seems important - it could create in you the expectation bias that you would not be able to differentiate.
What type of method did you use to compare the amps?
I'd answer the first question with a question: How does anyone expect to reliably differentiate anything when comparing two components sighted? Like I said, I made no attempt at scientific methodology, I just listened blind instead of sighted. What triggered the desire to test blind after listening to the tube amp and loving it for a couple of weeks? Curiosity. How did I do it? Split the output from the DAC, matched volumes to the best of my ability with a friend's cheap meter, and had same friend move the headphone jack between the two amps.
Could something in my methodology have masked a real difference between the two? Yes.
Tim
Deary me ...Straight from the mouth of a Radio Shack Merlin if there ever was one. Show me numbers.
That, unfortunately for just about everyone in this game, can be the real sticking point. A lot of the subtle tweaking that gets the best performance is not easily transferrable or translatable to another situation: the major reason that people who want extra performance quite often have a very hard time is that the changes for the good they do are very fragile in terms of of being able to make happen on command. In other words , you often can't just slap the bits together in a 1, 2, 3 manner and get the wanted result.If anyone could actually demonstrate in a reliable and repeatable way the things that the other party "knows," it would instantly become a part of the rational music lover position.
A bit like getting Formula 1 performance. If someone got the best engine in the game, the best suspension from another mob, the best brakes from a third, etc, and then just bolted or welded it all together in the back shed, how well do you think it would do on the track?
I think we're back to different realities here. As many people here will be happy to let you know, my reality is quite different from most. As an example, I barely worry about the bass, so long as it doesn't boom obnoxiously I'm OK with it; my obsession is with the treble, because my experience with this is that if you get this right everything else falls into place. The treble working right will give you tight, tight, thump you in the chest bass, which is what I'm after ...But that does seem to be the way "audiophiles" assemble their systems, by and large. Not much rhyme or reason, and certainly not much attention to things that actually matter.
Until/unless someone does the things that actually matter, listening to that person on the subject of power cords or isolation platforms or speaker wires or preamps or whatever is entirely besides the point. Wouldn't you agree?
I think we're back to different realities here. my obsession is with the treble, because my experience with this is that if you get this right everything else falls into place. The treble working right will give you tight, tight, thump you in the chest bass, which is what I'm after ...
Frank
My head is down when someone goes through so much work to run a blind test and it instantly gets dismissed. I especially disliked this comment from the mod (although stated as non-mod):Some of the problems associated with honest efforts with abx, http://www.hydrogenaudio.org/forums/index.php?showtopic=89779&hl= ,can be examibed by this effort on hydorgenaudio.
questionable method
refusable to acccept outcome by skeptics
problem with statistics. ec.
To get a bit more back on topic, I would further propose a test, nowhere near an ABX of course, where you use a highly respected, true 3 way speaker, true as in that the drivers do in fact cover decent ranges of the audio spectrum, not like a Zu in other words, such that the bass and treble drivers could be disconnected at will. Listening to good, conventional, music tracks, not bass freak thrashes, for example, which arrangement would people find more convincing and "attractive", and closer to the full speaker functioning: no bass driver operating, or no treble driver operating?
Or maybe this has already been done?? ...
Frank
Deary me ...
As in "Lies, damned lies, and statistics" numbers, or the ones the Japanese used to "prove" that their 70's amplifiers were superior or even perfect? I guess the next time I buy a car I shouldn't be so silly as to go for a test drive, but just find every printed number I can about the makes available: that will obviously tell me what is not up to scratch, and which is the best of the bunch ...
Frank
I agree that the midrange is where all the real action is, which is why is why the single driver crowd gets away with their type of speakers. What the treble does, for me at least, is add the icing on the cake: when it works correctly then the you-are-there element can switch on.By the way, the most significant thing for me in doing this sort of stuff is the realisation that it all matters. Play just the tweeter, and you WILL be surprised-depending on the crossover point-how 'little' there is in the treble. Once you do an experiment like that, it starts to put things into perspective. And very few do or have the means to do an experiment like that. One thing as a quick example, often people misattribute to the 'tweeter' what are mid problems. 5 k (as an example) is really high!! No, when people blame the tweeter, it is usually the mid IME.
Which hypotheses and how exactly would you propose to test them on me?When shall I expect you? It would do YOU the power of good to hop out of your ivory tower armchair theorizing and test these hypotheses of yours...I think you would learn a lot.
Let's see, from Wikipedia:Wow. A compound/complex straw man. Impressive.
Tim
I've emphasised the key element here: you would argue that it "unequivalent" and I would argue otherwise, on the basis that:A straw man is a component of an argument and is an informal fallacy based on misrepresentation of an opponent's position.[1] To "attack a straw man" is to create the illusion of having refuted a proposition by replacing it with a superficially similar yet unequivalent proposition (the "straw man"), and refuting it, without ever having actually refuted the original position.
