You do realize that Amanero now has a Super Amanero model, right?
Amanero has better software that Xmos.
By higher tier you mean higher price? I don't know a higher tier dac SQ wise than the Lampi, possibly because it is so DIYed
It is a quote of another person, Kedar. The post above is about adjustability of software not price. Oh dear.
No..AMANERO makes and sells the superamanero board. No need for diy upgrade.Okay - will give you the thread context so you can understand.
OP wants a new dac but tight budget. I recommend a used Big 7 but to mod with Dueland silver bypass on output caps and replace the Amanero standard board with one of these very cheap upgraded boards (less than £120).
I am indeed aware of the new Amanero boards but they weren’t supplied with the original Big 7 so moot in context of my response unless OP miraculously finds new budget and sends to Lampi for £1500 extra.
Again. Amanero is hard to deal with but has unbeatable software... hence why some people put up with it. Their upgrade promise dates are often missed but they have the best sounding software. Many manufacturers dont want to deal with him due to the issues.Is that the general consensus? There is an interesting post related to this on the Extreme thread and it seems Xmos appears more adjustable:
“Almost all XMOS drivers are configurable, the desired setting is either minimum latency, or its equivalent of a 1 millisecond buffer. It’s good to be aware that almost all of the higher tier DACs are using a XMOS USB interface. Another widely used USB interface is Amanero, but that is more often used in lower pricerange DACs and the DIY scene.”
Not at factory! BUY the SuperAmaneno from Amanero themselves and install. I said nothing about factory. And yeah, I know about the Aussie mod as I had bought the components a few years back but didn't follow thru.
BTW, have you ever tried to solder an Amanero to the Lampi, I did once and it was a nightmare. The points are tiny/almost microscopic and easy to screw up. It was a MIRACLE that I got it to work. Took a very long time of trial and error. It would be a snap for people who solder cell phone parts regularly, I suppose, but even at the factory, I was told that there is a high failure rate.
Gooood - glad to hear thatWork in progress with the "Silver Gate"![]()
I hope you will enjoy it as much as I did!...Silver gate on the way to home
More to follow, and a great thanks to Norman and Goran !!
Mainly KR...you aim at certain point in time for KR PX25RK and 242RK with the either RK 5u4g or USAF 596 recti and you can close the shop tubes related...now I think I’ll have to read all the tube rolling threads on this forum
Did you say EML or KR ?
