So there ya go, I reckon it would be easier to just buy well engineered products in the first place.
Yep.
Tim
Howdy, terry, a bit overcast and chilly, but we have an old slow combustion beast still working well, with plenty of fuel, courtesy of a neighbout paranoid about bushfires, so all's good ...good morning to you, how's the weather there?
Terry, all the relevant physical principles have been discovered, there are vast tracts of documentation describing how various parasitic behaviours of circuit elements make life extremely difficult for people in electronic engineering. The trouble is, none of those people are in audio! Track down a few papers of people trying to take precise measurements in some electrical discipline and discover the huge headaches and the sometimes unbelievable effort they have to go to to get meaningful results.Cables, we are back to THAT one too! Again, the science and engineering predict inaudible consequences, so naturally I will also expect to find new, completely undiscovered physical principles that will explain all.
Are there studies that show the effect of mechanical vibrations on SS components? (...)
The sad thing for most people, Tim, is that it is not trolling. I just came across another chap, on the Audiokarma forum who had my experiences back in 2004 and dared to post them. The level of negativity and almost vitriole directed back at him for daring to suggest such things looked very familiar; the poor chap ducked his head down, mumbled a bit about going his own way whatever others may think, and let it go ..... the response was just more unsubstantiated nonsense. It's a lost cause. It has even been suggested, reasonably, that it might just be long, elaborate trolling.
Tim
Well-played enough, Terry, but predictably, the response was just more unsubstantiated nonsense. It's a lost cause. It has even been suggested, reasonably, that it might just be long, elaborate trolling.
Tim
'strip
Could be important to repeat the question: Are there studies that show the effect of mechanical vibrations on Audio SS components .. if you are to detect cosmic ray or a soliton I am certain one will make sure that there is no source of vibration or any noise whatsoever .. We are talking here about audio and I would like to know if there are such studies (...) .
FYI, the microphony and vibration in electronics are extensively studied by the military
" means little .. A classical argumentation fallacy known as composition.the signals from a radiation detector have similar amplitudes of the low amplitude signals of audio
Fine that seals it.I think my previous answers were clear - as far as I know there are no published peer reviewed studies on the audibility of vibration effects in audio.
High End Audio and the military have the same type of problems!!??!! News to me ...If the multi-billion military industry in 2001 recognizes that they still on this phase what do you expect from high-end audio? They know they have the same type of problems, and also try to solve them by experience.
And sometimes it all comes undone. It's fashionable for some to laugh at improving electrical connections with various treatments but there was an instance of a mega expensive fighter splattering itself on the landscape. The inquiry's report: a wiring harness using gold plated contacts for the connectors developed a subtle corrosion between the gold elements which interfered sufficiently with flight controls to knock the plane out of the sky. I reckon the military would have got connectors of a fairly decent quality, probably a bit better than normal audio stuff but it still didn't help them ...the net result is a whole lot of sensitive electronics, much more sophisticated than high-end audio, are placed in jet fighters and subjected to vibrations that would make a train rolling by next to your listening room look like an undetected disturbance. And yet those sophisticated electronics guide those planes and their weapons with incredible precision.
'strip
Don't presume ... First your answer is too vague .. Radiation encompass a large spectrum of amplitude. You have instances in which the electronics have to be cooled at cryogenic temperatures ..DO we have such in our audio equipment ?
Yes, they also have problems with electronics microphony.I don't get the last part of your post High End Audio and the military have the same type of problems!!??!! News to me ...
The thing is, people keep ignoring the fact that the ear is an amazingly sensitive piece of kit: it can pick up deviations in the right circumstances of 1 part in a million; that's what 120dB dynamic range means -- it works like a CRO or multimeter with smart autoranging. You can mentally ignore what it's picking up, but if you decide to cultivate its capabilities you can go a long way, the "golden ears" thing".
So, components, always imperfect to some degree, combined with highly attuned ears guarantees that at least some people will pick up these differences.
They may ascribe these variations to really silly reasons or try quite bizarre ways to mitigate the effects, which will undoubtedly change the sound in some way for them, because they have sensitised their hearing to such a degree -- things may improve, but not for the reasons they believe in.
As regards the HT, remember this is to prove a point. I can go to a high end audio dealer any day and listen to how lousy half a million dollars worth of gear can sound, I'm trying to go a bit beyond that point. And it IS possible to turn a wreck into something capable of 150, there are examples at racetracks every weekend ...
Frank
The scary thing for the doubters, is that people like me will keep popping up, suggesting such deeply "controversal" concepts
Frank
I find what you're suggesting to be neither deep, nor controversial. It isn't credible enough to rise to the level of deep or controversial.The scary thing for the doubters, is that people like me will keep popping up, suggesting such deeply "controversal" concepts
Frank
