VPI ADS or SDS Speed Controller, Any thoughts?
Lee
4,130
2,496
1,810
Georgia
positive-feedback.com
Just wondering what sound improvements members experienced with either of these devices. I'm thinking about purchasing an ADS since SDS are hard to find on the used marketplaces.
Any comments appreciated.
The ADS at some point after start up, reduces the current therefore the motor is running with less vibration.
Of course the main purpose of ADS is to accurately adjust the rpm
I wouldn’t consider a VPI without the controller, it does improving the performance
Reactions: MJB and Lee
Thanks. What sound changes did you hear?
My issue with these is that they only have one channel output. The turntable still has to use a capacitor for phase shift for a secondary output. What’s much better is two sine waves 90* apart from a two channel amplifier driving them. That way you dont have an anemic secondary phase. It does require removing the cap, and making an extra connection.
Reactions: Lee
You will experience better dynamics, more details, quieter background.
You will have an overall sound improvement
Reactions: Lee
Thanks!
Reactions: Vienna
I have heard that a new generation of VPI controller will be launched soon, perhaps during next AXPONA
Reactions: Lee
Reactions: Lee
There is some speculation that a new ADS product will debut at Axpona. I'm trying to get an answer on that although I'm not sure I need to get a fancy one.
I believe that they will present a better one not a fancier one.
I think the new one will be equipped with feedback and continuous speed adjustment
Let’s see
Reactions: tima
Let’s see
That suggests the controller receives information from the platter and adjusts platter speed. Presumably the ADS works on belt drive systems.
If the updated ADS actually adjusts the motor based on platter speed rather than motor speed, that should be a improvement. Implmentation can make a pretty big difference: for example how many times the platter is read ... per revolution or per second, how frequently the motor is adjusted based on that information, how quick is the motor to respond, etc. There's still the potential latency of the belt versus the feedback to the motor. Nonetheless the new ADS could yield greater accuracy.
I have heard many things unofficially, let’s see which of them will be elaborated at last.
