Vincent,The power supply upgrade is now available.
The live-power is a special power supply making the sound of your Totaldac DAC or streamer better again, with a feeling of live sound.
This option is available in a small box with one output, or in a DAC-size single box with 3, 4 or 5 outputs and still with a single power cord.
Some very special transformers have been custom designed in France and are made in France for very efficient noise rejection.
The umbilical output cords are included with the power supply.
http://www.totaldac.com/live-power-en.htm
Hello Vincent,
Hello Vincent,preliminary specs are:
stereo power amp
RCA inputs
big Mundorf binding posts
220mm height + feet
500mm width
410mm depth
50kg
big power supply transformer
2*150W under 8ohm
2*270W under 4ohm
2*500W under 2ohm
stable under 1ohm
1.6V sensitivity
47Kohm input impedance
no global feedback
fully discrete design
triode input and solid state output
class AB (with medium level of class A for moderate heat)
wide frequency bandwidth and low noise
I am not sure to understand your question.What are the power output options of the power supply - both wattage and amperage? Thanks.
Sorry, I was assuming this was a standalone linear power supply to power your DACs and other third party devices, but I suppose they are dedicated to powering your DACs/Streamers only.I am not sure to understand your question.
Hello Vincent,CKKeung, you would like two XLR inputs, still with unbalanced signals? I have no plan for a balanced input on the stereo amplifier.
A balanced monobloc version, maybe later but not for Munich show.
I tend to use unbalanced amplifiers for myself.
This amplifier with RCA inputs is already more silent than many balanced amplifiers.
I can even use it on my 105dB horn system with complete silence at the listening point:
Hi Vincent,
Is it too early to enquire about the retail price of your new amplifier?
Is the "round hole" cooling slot arrangement intentional for improved shielding?
