Is this best value bookself speaker?
thomask
1,623
1,539
275
64
Washington State, US
https://ae01.alicdn.com/kf/HTB1KMiM...dth=748&hash=21df6a9e09d54a8392ec5833cc58ce05
https://www.aliexpress.com/item/Powerful-Sound-Hifi-Audio-10Inch-2-Way-Bookshelf-Speaker-Pair-For-Li...
868$ and free shipping to US.
Specification
Item Name: Bookself Speaker
Dimension: 38x32.3x55.7cm
Speaker Driver Size: 10inch (25.4cm)
Driver Cover: Yes/ Precision Mesh
Sensitivity: 97dB
Frequency Range: 28Hz ~ 24kHz
Peak Power: 250W
Recommended Power: 50W
Nominal Impedance: 4~8?
Net Weight: 16.95KG (37.36 lb)
Item Quantity: 2 Pieces/ Pair
Package: strong carton with wooden frame for protection
It has a 97db/w and could work well for tube amplifier and 28hz-24Khz.
It also looks good.
It can be best value bookself speaker.
Anybody want to try it out?
Loheswaran
437
101
273
There's a lot more t speakers than the sum of their parts - trust me I have made a sows ear with silk purse material...
Value is relative
Folsom
6,032
1,503
550
Eastern WA
Ha. POS. That is like a $2 piezo tweeter. Don’t kid yourself.
Folsom
6,032
1,503
550
Eastern WA
900$ speaker has no choice other than cheap part.
But I am still curious how it sounds with over excellent spec with the price.
Pfft. Bamberg sells some bookshelves with good parts for a steal.
Loheswaran
437
101
273
If you want to take a spin at the price - go for it.
That said there are some very good bargains out there already - Sierra s1 - I am told is superb - kef ls50...
If these guys do oem speakers for an established manufacturer u may be onto a winner - so do some research
But don’t look at spec sheets alone in evaluating a products - valve amps are a superb example of an engineering bumblebee - they shouldn’t work brilliantly but they often do (bumblebees shouldn’t fly apparently)
astrotoy
1,551
1,020
1,715
SF Bay Area
Look at the Elac line designed by Andrew Jones. Great sound for the price (as low as $299 a pair). Consistently rated the best sound for the money.
Larry
Reactions: Folsom
Folsom
6,032
1,503
550
Eastern WA
Larry
They are very pleasing on the ears. For the price they're crazy good.
bonzo75
22,640
13,668
2,710
London
Used vintage tannoys. Devons, cornetta, cheviots, monitor golds, depending on budget and taste. Devons and cheviots used upto 1k GBP, pretty large sounding and punchy and more natural than modern day Canterbury. These have 12 inch hpd drivers. Put in gold drivers and you get a bit more relaxed, pleasant sound (for those who feel hpd is aggressive), less bass. With red you get 16 ohms. Price doubles from hpd to gold to red because latter are more vintage. Reds were made in pre stereo era so you effectively have a set of two mono speakers.
Bodhi
1,051
361
155
There is a company in Germany called Fishhead Audio who build high quality speakers using AMT tweeters, carbon fiber cones, neodymium magnets etc & look contemporary. They achieve incredible value by selling direct. They have a 3-way bookshelf speaker which is only €799 and comes with a warranty. So the only real "buts" I can see are a/ you can't audition them and b/ they're inneficient @85db, 4 ohms nominal sensitivity (with a 3.5 ohm floor @480Hz). The above link is in German, so you need to open it up in Chrome using the translator fyi.
wisnon
3,536
640
1,200
Bookshelf?? These are too huge for that description, they are standmounts. They weigh 40 lbs each and are 22 inch tall by 13inches wide and circa 11 inches deep. Compare them to like the TAD ME1 and the bigger Harbeths.
The Dayton Audio with the Heil and the Elac or Pioneer from Andrew Jones are more the Bookshelf turf. Much cheaper too. Vanatoo is another bookshelf option.
Bodhi
1,051
361
155
I think you're reading the wrong information, the FA Resolution 1.6's are (WxHxD) 8.6" x 16.5" x 11.8" & weigh 22.7lbs, which makes them large bookshelfs.
wisnon
3,536
640
1,200
Bohdi, I was addressing the OP and the thread title. NOT FA.
I got it from here (ali Baba link above)... 557mm is like 22 inches. and it says 37.46lbs.
No bookshelf is this sturdy!
Gregadd
1,789
1,850
Metro DC
Value is a relative term, Remember you get what you pay for. Inexpensive is a different call. Now this speaker by Gamut is value. It sells for$21k! 20181102_155157.jpg
Loheswaran
437
101
273
This is possibly the funniest thread on wbf I have ever read. The poor op posed a question about a cheap high spec speaker he was thinking of taking a punt on - the response the wbf forums bold and beautiful opening the floodgates of every possible established alternative at a comparable or cheaper price. Love it.
Reactions: pweg
