MastersounD Spettro Preamplifier and PF100 Monoblocks
DSkip
442
195
350
Arlington, TX
www.audiothesis.com
I'm excited to announce that the first set of these fine machines will be traversing across the Atlantic this week. While both models have been in the US before, the newest versions have Litz-wired transformers to elevate their performance. They now boast 120 watts per channel of parallel single-ended goodness.
I was hoping they might make it in for my birthday weekend, but it looks like they'll have to be a belated 'present'.
For anyone interested in getting their ears on these, I am planning on debuting them at AXPONA 2019.
Reactions: the sound of Tao
As you know, Skip, I am extremely intrigued by that PF100 Litz. These comparisons would be extremely difficult to make happen, but I would be fascinated to compare the PF100 to a high power single tube SET (NAT Magme New SE, Wavac or AM 833) on the one hand, and to something like an Absolare 845 push-pull on the other hand.
I'm intrigued too. I've found myself, at least with MastersounD offerings, to prefer the parallel versions of their amplifiers in most cases. Many say that you lose the magic of the SET sound, but I've found the parallel to simply offer more control of the speaker from top to bottom with the same magic.
Wow! Fantastic!
What is it about tube amps? They're SOOO photogenic.
These are no exception.
Reactions: Ron Resnick
The KR va 200 is much superior to the Nat magma. The Nat preamps are better than the KR
Where you able to directly compare those pieces of gear?
I have compared the NAT Magma SE to various amps and the KR 200 to various amps. The attributes are consistent. The NAT has less drive, less highs, slow transients, very laid back. KR is is way more lively, great drive, energy, stage, complexity resolving. Regarding preamps, I have compared the NAT Utopia to AR Ref 3 and to Dartzeel (with Alieno power amp) and preferred the NAT. The KR pre lost out to even a yamamoto pre that was 2000 euro or so, to Thoress (which are remotely not my choice of preamps anyway). I also rotated valves on KR to check, and tried different amps. As such I don't think the pre warrants further investigation on my side.
Reactions: christoph
Next duel: KR va 200 versus MastersounD PF100!
You must have had those Nats on Mooks again.
Ked, you're such a Mooky puppy.
