Latest data on the website says 116db! Extreme...
ChrisAbsolutely![]()
I had used Full range speaker driven by 300B SET amp for 6 years."Latest data on the website says 116db! Extreme... "
Do you want to buy a bridge??? Really over what bandwidth is a single 8" fullrange driver in a back loaded horn going to deliver that??
Rob![]()
What full range speakers were you using with your 300b?I had used Full range speaker driven by 300B SET amp for 6 years.
But it has a limitation of bandwidth and dynamics although mid range is coherent.
It is very unlikely for me to go back to full range speaker again because of its limitation.
Regards,
Tang
Thanks for nice link.Another full range http://zero-distortion.org/yamamura-horns/
Chris
You really have nice systems including exotic horn speakers and Apogee Grand.
The Devore best worked with the NAF 2a3 8w amp (which is not a good 2a3er imo, it is slow for a 2a3).
Could you rephrase please. I dont understand.
Tang
I can think of linear speakers I don't like as much as the Devore. Thing with measurements is it focuses on the holes. Some of the good components do a lot of things other components can't and as a whole sound better. The Devore best worked with the NAF 2a3 8w amp (which is not a good 2a3er imo, it is slow for a 2a3). The main reason for using pnoes is to use them with amps that you cannot use on other speakers which has sonic benefits, so that combination is magical, and in the case of the General specifically his objective is also to keep out all crossovers, caps, resistors, out of his signal path.
No need. I understand now.If you answer this properly, I might https://www.whatsbestforum./threads/af3-premium-arrived.26477/page-3#post-543682
