Miyajima Zero
dminches
4,102
3,647
2,470
I just purchased a Miyajima Zero cartridge which I am going to mount on my SME 3012R.
For those who have used this cartridge what tracking force and loading did you prefer?
David, according to my notes, my Zero is set at 4.0 grams tracking. I think we did 1000 ohms loading. I remember the tracking force is pretty heavy. Stirling Trayle is my TT setup guy, so he dialed in things. My Zero is in a VPI wand. Good listening. It is a great cartridge. Larry
Thanks Larry. That’s what my dealer suggested.
David,
I’m tracking mine at 3.5g with great results. Antiskating set to 3.0
Do you have a Miyajima ETR-Mono? It’s superb with the Zero.
David,
So you are playing the ETR into your stereo phono? Are you throwing a mono switch?
David,
No, I am using my Doshi phono preamp with the Zero.
Unfortunately my phono doesn’t have a Mono switch. The ETR-Mono does output a coherent signal to both channels and it in the hands of faith to see if my stereo phono messes up.
I have tested the stereo phono once where I fed the Test LP Azimuth test track (with L-R at recorded 180 degrees difference)using a stereo Cart into the ETR Mono to collapse both channels which in turn goes into the stereo phono for playback. It was dead silent. From there, I am pretty comfortable running the stereo phono for mono duties as well. Give it a try.
My experience with the Miyajima Zero into my stereo phono pre is very similar to playing a mono tape through my preamp. No issues. What I get with a good mono recording is a fabulous big sound. I have to listen for specific instrument locations to realize that it is a mono recording. Otherwise, it just is a great big, wide and deep sound. The surface noise of older mono recordings is also greatly reduced. I play with the phono EQ settings on early pre RIAA mono recordings.
Larry
Larry
Thanks Larry.
