Double mica 5r4gy...they come in many brands...all the same. Haltron,CEI, Mazda,Zaerix, etc. Dont get Fivre or Marconi as they are way overpriced.
Right, ok, thanks Norman - same one as for the Psvane UK 300B’s then.
So this double mica is better than KR or Tak?
Cris you keep going back to coz you don’t have the taks hahahaa
Thanks, just to clarify, you have compared RK 300b to Tak 300b and found that Tak tubes are superior? I plan to do a comparison of RK 300 to 242 to Takatsuki 300b. Is it OK to use RK recti for this or should I try to get hold of Tak recti?I own them too. In the pacific the tak or we nos rules but some may like the 242 more and you don’t need a 900 tak recti for it.
Sorry I missed the last part both recti are good but if you can borrow a tak recti do so. It’s more refined in details and is better in some setups but not all. I also own a few nos we 274b and nos we 300b as well.
To me only the pacific plays 300b tubes well. The others show bloat and uneven sound
At a friends place not a worthwhile purchase
Have you tried a solid State recti
Yes
May I ask what dac you have I own many tubes not to shout on here.
If you ask I’ll comment but know always my views and I own a gg2 dac and has the Pacific DAC for 4 weeks
Anyone tried EML PX4 Mesh or EML 300B Mesh?
Also, looking at the internal construction of the EML 45 Mesh, I can't see any difference between that and the 6th Anniversary 45 Mesh apart from the top of tube supports, base and printing. Really there is none, or at least nothing you can see. Anyone got both and if so can they confirm if they sound the same?
