Impressive, but this one’s even more impressive........
I believe this one is servo controlledand we are looking at 1/1000ths of rpm...
david
How much does the speed change with the needle on the record ? How much does it fluctuate when “idling” ?
Centrifugal force is a fictitious force related to a constant spinning frame of reference it has nothing to do with balance ?
Euler's force also fictitious can be created by alterations in speed [ie accerelation] of a spinning system, thus a fluctuating speed could create this effect, but its not a real force, but a symptom of the inertia of the object spinning....if your referring to sprung platforms is this what your referring to? the upset of the platform as the platter accelerates and deaccelerates?
No speed slow down when you lower the needle ? That is VERY impressive !1) No needle effect on speed.
2) +/- 0.005 when idling.
I can snap a picture at 33.333 and 45.000 quite easily.
Kind regards,
Tang![]()
Wow David, fantastic stats and beautiful craftsmanship, truly a work of art !Max overall speed fluctuation is within 0.005rpm, with supplied belt needle in the groove doesn't affect speed.
david
david
3012R with GFS is on now. Can’t use the SME headshell because the flower body of GFS is too big. So Arche headshell is used instead.
Tang
I haven’t measured the weight. But it sure is heavier than the SME David. The GFS is pretty heavy too. Everything is new, the cable, the GFS. So I can’t say much about the sound yet.How how much does that headshell weigh, it looks heavy? Usually SME works best with a minimalist headshell similar to their own.
david
Thank you Lagonda, appreciate it.Wow David, fantastic stats and beautiful craftsmanship, truly a work of art !
Tang
david
It weighs a ton (Arche'). When I used it with a Lyra on the SME, the counterweight to get arm dynamically balanced almost maxed out at heaviest counterweight setting.
So, are we saying the AS is as speed accurate as the current king of uber precision, the Monaco 2.0?
