it's all about signal to noise.
judge not, yet yee be judged.....or something like that.
and you make lots of noise (judgments). so 'much' is then expected.
Umm...ok Audio Jesus, Mohammed or whoever.
Hello and good afternoon to you Gentlemen. Can we steer this thread back to it's topic and lose the off topic posts please?
Thank you.
Tom
Agreed. Disagreements on audio does occasionally lead to so very entertaining banter, but this is a celebration and lets move back to that focus shall we?
Would this tell you how it sounds??
Some people talk and back IT up with pics , makes IT more Interesting for others.
If you only talk how good IT sounds ,IT stays a mysterie lol
I completely agree pics mean nothing especially with unfamiliar gear. With familiar gear best you can know is if speaker is over sized for the room or too close to the wall for speakers that shouldn't be. Maybe some mismatched components if you are familiar with the gear but you doubt need pics for that. Rest is patting yourself on the back that you have figured out the sound long distance
From pics i can easier see if someone talks a load of **** OR not, to put IT in a simple way
Let's get back on topic: I'm sure it's all awesome. The speakers use a smaller bass driver than I would expect, given the transition from the mid horn and thinking of matching dispersion. But hey, if the ViV Float tonearm can break literally every rule and have ardent fans then...
from pics i can easier see if someone talks a load of **** or not, to put it in a simple way
