Yes, you are at the risk of damaging your equipment. Mains in Japan is 100V, equipment manufactured to work in Japan can work safely at 100 +/-10%, that can be out of the US mains. Although I have a step down transformer to operate US equipment, I had to use a separate one for japanese equipment - and no, it was not a SP10, mine fortunately was 230V!
Does a step up / step down transformer change the sound?
A well chosen transformer will NOT change the sound. However a poor transformer that is too small or the wrong voltages or mis-wired might.
For those that are skilled working with AC power a boost-buck transformer is the way to go.
Only with a poorly chosen transformer.Not with motors but definitely does affect the sound of electronics!
david
Transformers that step 120V down to 100V are not all that common. It's not like looking for 240V to 120V transformers, which are plentiful.Thank you so much. Are you thinking of any particular one or 2?
Do you have any skilled electrical friends?
Even so called audiophile grade transformers when used in line with equipment will impact the sound and IME always negatively. Up & Down inverters are mostly cheap commercial products with no consideration of sound quality. Now if you’ve found a high quality one that doesn’t kill the sound I’d like to know about it.Only with a poorly chosen transformer.
Check Amazon for a startTransformers that step 120V down to 100V are not all that common. It's not like looking for 240V to 120V transformers, which are plentiful.
My contractor, who did a lot of work on my house, is very skilled. But this work will only if I ever pick up a rare-to-find SET from Japan
Thank you
Caesar, what are the rest of your systems apart from the MBL one?
