It’s okay Mike, nothing wrong with the 80% rule...
Cheers!
Alan
Cheers!
Alan
Thanks Alf. Looking forward to hearing what you changed too.![]()
Imo the best path is as rockitnan suggests and that is with a Lamm preamp
Sorry Doc, I think this is a silly recommendation based on the Lamm posse and nothing else.
There are plenty of people who match SET amps with other preamps - and SS should work arguably the easiest as there is no impedance issue.
Noise has nothing to do with his preamp, guaranteed.
ps. having dual volume controls with no remote is a *big* issue for many of us too. I frankly don't believe Vladimir at all on this either.
Dartzeel pre / power
Ps i fully agree with the pre amp idea
that's cheap I spent $120000 on my tenor pre amp lolwhat's another $25-30K(LL1) between friends ?![]()
I know someone who said the Dart pre sounded better than the Shindo pre with his his Shindo power.
This has to be taken on a case by case basis.
Here's another thought....( since I am a big believer in a tube preamp over a ss preamp)--- dump the Dart preamp and acquire the Lamm preamp. This way the ML3's will be happy...and so will the Dart amps![]()
My advice for what its worth , get the Lamm pre amp to get the whole Lamm thing over with/ or not , keep both the dart combo and the lamm combo , if possible half a year at least and then sell what you dont like plus give at least the lamm pre a go at the 458 s
no. the ML3's are guests in my system. they have a limited performance envelope. that's not what my system agenda is.
